Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
Electrolux refrigerator is not keeping things cold, but the freezer is workng. I think it could be the temperature sensor (thermostat). Any ideas?
The Electrolux refrigerator is not working it's not cold but the freezer is working I was told it may be the thermostat. Food and milk in fridge is getting spoiled. It's been out for 3 days already. Thank you for any help.
2 Suggested Answers
machinetech7
  • 1344 Answers
SOURCE: The Electrolux refrigerator is not
First thing to check is if (a) the evaporator fan is running in the freezer and (b) if there is a build up of ice on the freezer wall. If the fan is not running in the freezer the ref. side won't cool. If there is a build up of ice on the freezer wall, then you a defrost system problem and there won't be any circulation to the ref. side. If you have a defrost problem, the defrost system consist of 3 parts: timer, bi-metal thermostat, and heaters. With fridgidaire more than likely the adaptive defrost board(timer) located in the fridge on the upper left side behide some white pastic is bad. If you change it go ahead and change the bi-metal thermostat, located behind the freezer wall, as well because its a very cheap part and will save you from having to do it later.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Nov 01, 2010
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
Miele kf 3855 s-6 fridge part not working. Where is the thermostat?
The PCB is probably the temperature controller and most likely uses electronic temperature sensors in the refrigerator and freezer sections. Not having seen this model before, I'm guessing, but perhaps there is a problem with defrosting such as a clogged defroster drain tube, and the insulation between the freezer and refrigerator is iced up. This could also coat the refrigerator temperature sensor in ice if it is on the divider between the two compartments, thus fooling the controller into thinking the refrigerator is too cold. A manual defrost or drain tube inspection should rule this out.
Jul 16, 2017 | Miele Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Refrigerator compressor keeps running
This can be a tricky problem. There are three things that I can think of that can cause this. First is the defrost timer. To determine if this is the case look in the freezer at the freezer back wall. Is it cover completly with snow like ice? If so the timer is not letting the machine go into defrost. Also you should notice the fresh food part of the machine start to rise in temperature. The next thing is the machines cold control thermostat is faulty and even though the machine maybe cold enough the thermostat can't tell so it never kills power to the compressor. The last is that your machine is low on freon, so the freezer temperature never really gets low enough. Signs of this are decrease in ice maker production, ice cream softer than normal, or put a thermometer in t he freezer. The temperature should be around 0 degrees F and no more that 5 degrees F
Apr 27, 2012 | Refrigerators
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Freezer Freezes Refrigerator Barely gets cold
Hello there:
Here is a few things to check to make sure the referigerator is working properly.
The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system,
Apr 14, 2010 | KitchenAid Architect 24.5 Cu. Ft....
Our fridge, a Zanussi Electrolux, temperature guage warning us something is faulty. It is not cold enough and struggling but still working. The freezer below is working O.K.
Couple of possibilities.. If there is a fan or vent between the fridge & freezer, it may need to be adjusted.. Or the simplest thing is there might be one or two thermostats controlling the temperatures of both the fridge & freezer. Maybe you can adjust the temperature that way. Sometimes a door heater can cause an unexpected change in temperature.. Check to see if there's unusual heat around the door. Also, test the temperature using a different guage, as it may be faulty. The bottom line is that it could be low in refrigerant gas, if thats the case you need special guages, leak detector, charging cylinder etc. Quite hard to fix. Is the compressor running for long periods of time? If so, maybe it's never satisfied & the system does have a leak. Anyway, see if you can test (ice or spray can of freeze) the bulb or sensor on the end of the thermostat. Replace it if it's faulty, it's the easiest thing to fix. Rgds.
Apr 30, 2008 | Refrigerators
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven't got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren't any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
851 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
