Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer Spooler Service turns off when I try to print
I have a canon pixma mp160, the inks are brand new, the paper is full. I connect it to my laptop by usb. It worked fine and then for some unknown reason, it stopped working. When I ask it to print, it tells me the printer spooler service is not running. So I turn that on and ask it to print, and it turns off the spooler service and tells me things like bi=directional support is not enabled. I found that and it was enabled already. What else to do?
  • 1 more comment
  • allyall Oct 12, 2007
    My problem is still not fixed. In fact, I can add that I know the connections are all good, since the scanner on the MP160 works fine. How do I make it work?
  • allyall Oct 14, 2007
    It must be a windows problem, because I have done this several times. Thanks for answering.
  • khogen_heisn Sep 29, 2008
    while adding canon bpl 29000 printer to my pc massage 'spooler is not running ' is coming
  • Canon Master
  • 705 Answers
Un-install the printer and it's associated software via the Control Panel of your Windows PC.
Reboot your computer with the printer turned off and the USB cable unplugged.
Go to the Canoin web site and download the latest version of the driver for your operating system.
Run the driver install following the instructions in the install wizard.
Once the wizard is done, you should be OK again. If not, reboot and test the printer again. If it is still not working properly then you probably have a Windows problem and not a printer problem
Posted on Oct 14, 2007
Spooler service has stoopped
Posted on Dec 23, 2007
SOURCE:
Error 9
Is there a camera or smart card connected to the printer? This error usually has to do with an unsupport camera or card being connected.
Feb 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full so printer wont print
yes, printer wont print and see screen message
Use this method below with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Use MPTOOL to reset waste ink absober full on pixma mp160.
Download your Mptool first http://www.ziddu.com/download/8524406/MPTool.rar.html
Download manual guide how to use Mptool on pixma mp160.
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help......
Jul 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Changed the ink cartridge when i turn it on i get e 2 and alarm
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq8
Jul 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Help me
hi,
ptttq9
Jul 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 flashes when turned on
hi,
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer not working properly
MY PIXMA printer will not print after I replaced the ink. The error message says the ink is full. What should I do?
Dec 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon printer mp160 e27
how can i get my ink absorber to be unful and work agian so i can print again WANALI
Aug 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
88 people viewed this question
Clive
Clive
old marine
old marine
Ekse
