If the problem is due to warped brake discs, you will typically feel a mild pulsing in the peddle when braking firmly. Also, when you are experiencing this shudder, taking your foot off the brake (when safe to do so) should cause it to stop. If that is not the case, I would consider again the transmission. I am on my second Caravan, so I speak from experience. The Caravan transmission should have the fluid changed every 30,000 miles to keep it in top performance, especially if you are carrying any heavy loads or pulling a trailer. When you are slowing to a stop, the transmission must downshift through each of the gears. If it stays in the higher gears at too slow a speed, you will feel a shudder. Sometimes this can be corrected by changing the transmission fluid. Be sure to use the proper Chrysler fluid for your transmission. Typically it is the highest (overdrive) gear that causes the shudder. You can determine this by moving the gear selector from "D" to "3" when you are experiencing the shudder. Other possibilities are alignment, worn stabilizer bar bushings, worn ball joints, and out-of-round tires. Most of these also involve some accompanying noises though. Good Luck.
Try checking out the brake discs or rotors. They have a habit of warping and causing this problem . Check bake pad thickness as there may be metal to metal contact. Check frond end suspension rubbers as if they are worn then the shudder will come from a loose front end.
Testimonial: "Hello Bill,Thank you very much for the various suggested solution. Neville"
Warped rotors?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: Car shudders on acceleration
I'd check the motor mounts. Shuddering upon acceleration indicates movement of the engine inside the compartment. Best of luck.
Greg
SOURCE: 1999 Dodge Ram 360 5.8 liter engine feels like transmission is sl
Hi, the problem you are having sounds like the differential needs replacing this can be expensive and hard work but not doing this can cause further damage to your vehicle so its better get it done sooner rather than later.
If on the other hand your only getting a vibration through the steering wheel then this could be that the wheels need balancing.
You should know which of the two problems you have if you need further assistance then just let me know ok
