Question about Lands Phones
I have the Uniden DSS7955 + 2 - it it on the same line as my broadband computer line and am getting constant static. When I disconnect the broadband line, the static disappears. I had an older model Uniden on the same connection and this didn't happen. What's the solution?
  • 37 Answers
You will need to get a DSL filter to separate the DSL(broadband) from the talk line. These can be purchased at any store that supports computers.
Posted on Apr 19, 2009
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Phone line static
with the modem disconnected and the static is still there , indicates a problem service land line
ask your service provider for a line check because of the noise
Nov 22, 2017 | Motorola Mobility MD481SYS Cordless Phone
Phone disconnects and shows "out of range of base" during calls
Press "Menu", Select "Handset Setup", select "Select Base", and then on that Select Base screen, move the arrow next to "Auto" and press select. I have been told this should solve your problem.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Constant static and interference
I have found that dimmer switches might be the cause your problem. If you have any around the house you may want to change them to a regular switch.
To test to see if this is the cause, turn all your dimmer switches completely off (not just turned down). See if it clears your static issue.
Sep 01, 2008 | Uniden Cordless Phone
Our 5.8gh uniden phones all have static one land phone 3 extension.
disconnect the ac adapter from the base - before you plug the phone back in with power - press and hold down the menu button (center silver button under the led display) and the number "1" and then plug it back in - keep holding those two buttons until the date and time reappears - it worked for me and it didnt erase the phone numbers stored in the base unit.
Jun 01, 2008 | Uniden EXA15580 Cordless Telephone
Virgin broadband to laptop
Try setting a static IP on your computer with the DNS provided by the modem- to set this up contact Virgin and have them help you setup a static IP(or if you know how to set static IP on the computer use the same IP information you getting from the DHCP).
May 13, 2008 | Belkin (F5D9230-4) Wireless Router...
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Lands Phones Logo
132 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
