Want to disable the mouse stick on a Dell Lattitude 6400
How to disable the mouse stick on a Dell Lattitude 6400. Control pannel, mouse settings does not have the option which will help disable the mouse stick on the key board.
  • rahul180981 Apr 17, 2009
    the Use Stick Keys option is already unchecked in the accebility options... and mouse options do not have any Use Mouse Keys option to uncheck...
    Problem Solver:
Go to control pannel and open accessibility option and uncheck the Use Sticky Keys box. Then click ok.
Another one in accessibility option click Mouse option and uncheck the UseMouseKeys. Then clik ok.
Posted on Apr 17, 2009
My dell inspiron 6400 touchpad scroll not warking with window 7 ultimate
Try going to Control Panel - Hardware and sound - mouse. Once you have the menu for the mouse open, go to device settings. Click settings, and all of the advanced controls for the functions of your mouse pad can be found there.
Mar 12, 2011 | Dell Inspiron 6400 Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do i disable the touch pad on my Dell Lattitude E5400 laptop? Thanks, Tom tc@tc-talent.com 917-733-5968
You can turn off the touch pad through the mouse settings in the Control Panel. I was a little frustrated by this too, but if you go to the Control Panel and click 'Mouse', the first tab of this new window is 'Dell Touchpad'. Simply click anywhere in that window and you'll be able to configure the touch pad settings. One great option for many people is 'Disable Touchpad/Pointing Stick when external USB mouse is present' as there is no easy one-button solution to disable it.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Dell Latitude E5400 Laptop
How do i disable double click on my dell touch pad?
go to the control pannel and mouse options, there will be a single click/double click option as well as speed variables
Oct 09, 2009 | Dell F3534 Touchpad
Touchpad Sensitivity
Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
Mar 28, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 6400 right click dosent work
Go to control panel and Mouse settings. Make sure settings are set up correctly. Same place for the Touchpad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
Dell Touchpad
You should be able to disable the touchpad from within the mouse properties in the control panel. Uncheck the enable touchpad option in the devices section.
Feb 22, 2009 | Dell Inspiron 6400 Notebook
I would like to deactivate the mouse pad in a DELL Inspirion 6400. I look everywhere even in SETUP without success.
Go to Control panel, Mouse Properties, On the Devices Tab, You can disable there. It that is not an option, install the Synaptics driver, then you'll have the option.
Jan 18, 2009 | Dell Inspiron 6400 Notebook
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Computers & Internet Logo
392 people viewed this question
David Payne
David Payne
