Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Brother MFC8840D only 4 rings before fax pickup?
Our MFC-8840D has been lovely for print/copy, but I'm now trying to make it our fax machine. It shows only 4 rings as the max before auto-fax-pickup, but my answering machine needs those 4 rings before *it* picks up. Any way to circumvent the 4 ring max on the 8840? I can't reset the answering machine to 2 rings (it's only other option) because we'll never be able to get to the phone in time! Thanks.
Yes, I know that from the manual ... that's why I'm asking if there's an undocumented way to circumvent the 4 ring max on the fax machine. I guess there's not one that you know of, huh? The other faxes I've used had a 5 or 6 ring setting, but this one maxes out at 4 rings, which isn't helpful. -di
Posted on Sep 16, 2007
    Problem Solver:
  • 9 Answers
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
  • Henry White Sep 16, 2007
    THIS IS ALL ON THE USER MANUAL
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
BROTHER MFC8840D IS THERE A WAY TO SHOW THAT I SENT A FAX TO A SPECIFIC PHONE NUMBER AT THE END OF MAY?
Possibly. The Fax Journal has the last 200 faxes (incoming or outgoing). Press Menu then select Fax (up and down arrows). Press Set, and use the navigation keys until Setup Reports or Report Settings appears. Then press Set and use the navigation keys to find the Act. Interval or Journal Period. Press Set again and a length of time for the Journal (anything but off). Press Set again. (If you use the 7 day count-down, you will get additional queries for day of week and time of day for the start of the count-down.) Press Stop/Exit and the Activity Report will print when 200 faxes are in memory, the memory is full or the desired time frame. (The setting of 50 faxes will print at every 50 faxes.) After printing the report, these entries will be deleted.
I hope this helps.
(if the report was already generated, you won't get the old entries. Similarly if the memory was cleared after an Out Of Memory error, you won't find this entry. If Fax Storage was on, you may be able to actual get the original Fax. Menu > Fax > Remote Fax Opt > Print Fax or Print Document. Then Start and when all stored Faxes print hit Stop/Esc.)
Aug 05, 2010 | Brother MFC-8840D All-In-One Laser Printer
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Hi dear why my mfc8840d can't switch from fax function to copy and scan function
It sounds like you have some sort of printer error, you can try holding the stop button as you power up it will either tell you the error or clear it so you can copy and scan again.
Feb 01, 2010 | Brother MFC-8840D All-In-One Laser Printer
EVERY TIME I PRINT OR GET A FAX ON MY BROTHER MFC-8840D FAX IT SHUTS MY COMPUTER DOWN
Fax is an operating system setup utility...perharps you have backup file that are corrupt in your operating system so, Repair your operating system and try it again.
Sep 30, 2009 | Brother MFC-8840D All-In-One Laser Printer
Won't fax
You have to get your answering machine and your fax to play nice. Read the instructions for both. I think I have my answering machine to pickup at three rings, and the fax to pick up at five. Don't have the fax answer first. Don't have both machines answering at the same number of rings.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
1) fax problems 2)change drum (already did but nd to chng count?
1. Open the front cover, and then press Clear/Back.
2. Press 1 and when the LCD shows Accepted, and close the front cover pressing firmly on each side until they click into place.
Feb 19, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother mfc 3100 c
Are you sure it's not a problem from the sender?  Have you tried asking someone else to fax?
Aug 14, 2007 | Brother MFC-8840D All-In-One Laser Printer
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
