Question about Cell Phones
Nokia2660 earpiece not work - Cell Phones
N72 network
Posted on Apr 16, 2009
Earpiece dosen't work
The earpiece have to be replace but the problem is that you have to find one from another phone cz they don't make replacement part for that phone
But they do have the speaker on ebay
If you look little harder you will find the earpiece
Dec 27, 2012 | Samsung Glyde SCH-u940 Cellular Phone
Earpiece
Be certain your radio is turned off when you initially plug in the earpiece, then after turning on the radio, immediately press the PTT on the earpiece. On most models this initialization syncs the earpiece PTT to the radio. We have experienced a few older model radios which require the radio's PTT to be pressed once, followed by the eapiece's PTT, to initialize, but this is rare. The other possiblity is the earpiece was not made to match the radio you are using it on. The position of the rings on the 2.5mm and 3.5mm jacks can make a difference between models of radios.
Best regards.
Jun 27, 2012 | Binatone Terrain 750 Twin - Black
No volume on incoming or outgoing calls unless using the loud speaker
the problem of your phone is in the earpiece.... try to open or dismantle your phone if you know how to dismantle... get a tester to check if your earpiece is still working.. and if not, u need to replace your earpiece... but if still working, try to clean the earpiece terminal maybe it is just corroded or dirty... goodluck my friend....
Feb 27, 2011 | Cell Phones
Nokia 1208 earpiece problem
Hi, Earpiece can get damaged if there is dirt or the earpiece is totally damaged.
You can clean up the earpiece and see if it will work, if it doesn't work, you will need to replace it.
Thanks for using fixya.
Sep 30, 2010 | Nokia 1208 Cellular Phone
AIR PIECE IS NOT WORKING
If the earpiece of your phone is not working, it means the earpiece of your phone is bad and will need to be replaced.
All you need to do is to change the earpiece of your phone and you will see that you can hear what people are saying while making or receiving calls.
Change the earpiece as advice and you see your problem with the earpiece is solved.
Take care.
May 06, 2010 | Cell Phones
My phone only works with the earpiece or speaker
the Motorola phone your talking about is not specified.First the problem can be solved.
It is an earpiece problem.The earpiece it faulty and it needs a replacement.
NOTE:
Some Motorola phones earpiece is attached to the flex of the phone, while some as an earpiece, which the flex is it can still be fixed.
Mar 15, 2010 | Cell Phones
I can't hear the person talking on the phone earpiece. The volume is on high and the speaker phone works fine?
Sir/Maam,
It can be that the earpiece is broken. Try calling someone without using any earpiece, if that works that proves the earpiece is damaged or broken.
If that doesn't work, then the speaker in your phone must be damaged.
Hope i helped you, thanks.
Feb 27, 2010 | Cell Phones
The earpiece does not work
99% of a non working earpiece is in the earpiece itself.,in the wire,in the part of Jack's root.Due to a regular movement when you are using it there is the risk to cut or detach the very thin wire on it..But,on the other hand,check your earpiece to use it on other cellphone,and if it works,then the problem is on your fon itself.
Nov 05, 2009 | Motorola Mobility i776 Cell Phone
Samsung alias earpiece speaker
Possible the earpiece has gone bad. Can you test with another earpiece?
Remove battery and examine metal contact points for dirt. Can clean with a pencil eraser.
Jul 19, 2009 | Verizon Communications Samsung Alias Cell...
Nokia 2660
You can get your PUK Code from your service provider. Should be a quick call after they verify your account info. Unfortunately there is not DEFAULT PUK Code and provider is the only one that can tell you what your SIM PUK was set to.
Please don't forget to mark if this solution solved your issue.
Sep 09, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
