Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Changing Paper Tray Through Code
I need a shell command using which I can print first page of my document on tray 1 and rest on tray 4. Is it possible ?
  • 167 Answers
Use the Cover options in the PerPages Tab of the driver.
This should give you the resultsa you desire.
Set the job to come from Tray 4 and then specify the "cover" from tray 1
Posted on Apr 27, 2009
Its prints one page at a time and a pop up appears that says "press cancel button (manual feed mode)". I do this and nothing happens. Why will it not just print the entire document at one time? I...
You need to change the default tray. Thats the reason its printing one page at a time. You can change the default tray to draw paper from two ways, by using the controls on the printer itself or by changing the settings when you print a document.
To change it on the printer, go to menu on the printers keys and scroll the options until you find the print settings. Use the up and down arrows to scroll and press enter or OK when you find print settings. Continue to scroll until you see the default paper tray and change it from the manual feed choice to the default paper tray.
If changing from the print settings in the computer, when in a document that you want to print go to file at the top of the page and then print and click on preferences. Click the tabs at the top until you see the paper tray that is currently being used and click the arrow next to it to change it to another. Then click "ok" and close everything.
Dec 07, 2010 | Samsung ML 2010 Laser Printer
Brother MFC-9840CDW says no paper when trying to print. there is paper, it will make copies and test page, but beeps and flashes no paper when printing. Says "reload paper in MP tray", I've taken out all...
I had this problem trying to print from MS Word in a template I downloaded. I found this link and it worked perfectly. I'm using Word 2010 so I had to adjust accordingly. It's for a slightly earlier Brother model but that did not affect my using it.
Jul 15, 2009 | Brother MFC-9840CDW Laser Printer
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Brother printer problem
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Oct 02, 2008 | Brother HL-2040 Laser Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Jul 02, 2008 | Xerox Phaser 8560MFP Laser Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
65 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
