Sound is absent from pc - Computers & Internet
  • Thomas F. Schneider May 11, 2010
    Reinstall both the sond software and the driver.
Adapter is connected but battery is not charging, no indication
Check the voltage at the pin of the adapter, if absent then the adapter is faulty. If present then there must be votlage at the reminals of the battery in the laptop. If absent there are errors in the mother board , charging circuit.
If not the battery can be faulty and so swap a similar battery to confirm before you buy a new one.
Aug 08, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have a 50 inch lcd tv,the sound works but no picture. What could be the problem?
your problem is in the video section check your video ic 201 the number 1 pin should be getting 5 volts dc input if the voltage is absent then checkQ 210 it could be bad replace it.if the 5 volts is present check the ic output for 125 volts dc if absent replace ic.good luck.
Feb 27, 2010 | Televison & Video
Presario S5000CL will not start.
The beep sound basically comes when the RAM module is malfunctioning,blown out,loose contact or absent.It may also occur when the graphics card is malfunctioning.Solution:Remove the RAM module ,blow off any dust and fix it bak firmly.
Oct 09, 2009 | Compaq Presario 5000 PC Desktop
Sound drivers absent after formatting the machine
open link and download driver ......
http://www.mercury-pc.com/downloads_list.php?productid=439
Oct 06, 2009 | Mercury PVCLE266 Motherboard
No sound coming in compaq presario C700
Evidently you downloaded the wrong drivers. Check make and model of your sound card, or check the onboard sound in the "DEVICE MANAGER." (I'm assuming you run Windows XP). Go to the correct manufacturers website and get the right drivers. Or, it could be something as simple as the speakers are muted or disabled. Go to control panel, sounds and audio devices and make sure speakers are enabled and turned up.
Jun 25, 2009 | Compaq Audio card Sound Card
The sound on my windows media player and itunes dont work
The driver has been deleted. Try reinstalling the driver software.
Jun 14, 2009 | HP Compaq nx6115 Notebook
My sound card is absent
if there is no sound in the machine just do the system restore on the date where you think it was working fine , you will not lose the data after that also but but the updates will be lost . and you can do the system restore by going to
START - PROGRAMS - ACCESSORIES - SYSTEM TOOLS and then SYSTEM RESTORE
Mar 26, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Sound driver
go to their website and get the system drivers..
Mar 28, 2008 | Everex GA3400 Refurbished AMD Desktop...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
