Keyboard will not work
I changed the ribbon & corrector ribbon, now the keyboard will not work.
When I switch the machine on, it sets itself ready to go but keys will not operate. It's almost like there is a keyboard lock operating somewhere, but I cannot find it
  • 2 more comments
  • ted_donovan Apr 20, 2009
    Dear DickyO,
    The model is a Panasonic KX-E4000 electric
    Very many thanks
    Ted
  • ted_donovan Apr 21, 2009
    It is a Panasonic KX-E4000 model electric typewriter.
    Many Thanks
    Ted
  • keith640 May 11, 2010
    What is the Make and Model?
  • Dick O Reilly May 11, 2010
    Make & model?
    DickyO
  • 3,594 Answers
A few things to check, be sure the upper cover is fully closed, be sure the printwheel is properly installed and latched in place. check that the ribbon is properly inatalled, put the old ribbon back on and see if it works.
DickyO
Posted on Apr 22, 2009
How to install corrector tape into AX325. Seems to be in place and black ribbon seems to be in place but corrector tape does not work
Be sure the correction tape is thru both guides and that the dull side faces the paper. Go to brother.com click on support you will find a manual there.
DickyO
Mar 27, 2012 | Office Equipment & Supplies
Hi i had problems with the touchpad keys and keys not working, tuch pad did work for a while so know it was not driver problem and as my friend gave me this EEE PC 900 as its screen was broken which i...
the keyboards break real easy they are easy to change there is 2 or 3 tiny clips along the top of the keyboard you have to push them back with a small screwdriver and lift the keyboard away and disconnect ribbon from the main unit, the touch pad is built into the case and connected to the main board with a tiny ribbon connector, check the ribbon is connected correctly, be carefull its easy to break off if the case is opened, if it looks connected ok but still not working check the driver is correct, the drivers are available from the asus website
Jan 14, 2011 | ASUS Eee PC 900 Notebook
My Emachines calc. Hot key backward and forward hot keys do not work
A; key is stuck (as in something sticky or some object needs removed)'-- Use isopropyl alcohol, a Toothbrush and some pipe cleaners... apply it liberally with the pc OFF - wait for it to dry - then try... (avoid using any cleaning material that will leave residue or pieces of itself - no WD40 & no Qtips! They may work good on SOME computer components - but not for a keyboard)
B: your ribbon cable could be damaged or not properly inserted. Take out the keyboard - reinstall carefully - sometimes these ribbon cables can be loose, in the wrong position, not properly inserted - or damaged.
C: Maybe part of the key is broken (5.00 on ebay for one key or 25.00 for a whole new keyboard)
Jul 03, 2010 | E-Machines AAFQ50400000K0 Keyboard
Character keys problem
I doubt the keyboard itself is at fault. Try it on another computer and see if it does the same thing. If it works okay on the other system, then the Keyboard settings on your machine were probably changed. Go to the Control Panel and look at the Keyboard or Regional Options entry, and make sure that it is set to English. If your computer has foreign language support turned on, there may also be a control in the system tray at the lower right of the screen that has been changed from EN to some other language.
Mar 13, 2010 | Trust Keyboard KB-1120 Keyboards
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
This machine gets used just a few times a year for straight typing. I was asked to replace the ribbon as the letters weren't appearing on the paper when the keys were pressed. No one knew when the last...
I'll assume this is an ibm ww. Just below the ribbon deck on the right is the ribbon feed motor try na little WD40 on the upper and lower bearings they do gum up also be sure the ribbon motor is plugged in.
DickyO
Oct 06, 2009 | IBM Office Equipment & Supplies
Corrector isn't working
You may be puting it on wrong the dull side of the tape should face the paper.
DickyO
Sep 29, 2009 | Brother ML-100 Typewriter
Fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Oct 28, 2007 | Smith Corona Wordsmith 100 Typewriter
123 people viewed this question
jasbo
jasbo
