DAO in vb
In my project... i have to create 1 listbox,4 command button and 9 label... by using ms-access as database i created one table... 1 table empty.. i want to know how to spilt the items and insert into 2nd tables and to reduce the min value
    Brigadier General:
  • 10,406 Answers
Nice try. Find an upper-class student to give you one-on-one tutoring with your homework.
Posted on Dec 02, 2009
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
How to make a code for log in using database?
RIGHT CLICK ON MY COMPUTER AND SELECT THE MANAGE AND SELECT USER AND GROUPS CLICK YOUR USER ON WHICH YOU WANT CREATE PASSWORD RIGHT CLICK THE USER AND SET PASSWORD AND FILL THE PASSWORD AND ENTER NOW YOUR PASSWORD WILL SET ENJOY
Oct 21, 2009 | Microsoft Visual Basic 6.0 for PC
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
How to add items in combobox using database in vb6.0
There are 2 ways:-
you can set the recordsource in the properties for the comboBox to a table or create a recordset and loop through it adding one item at a time, see example below:-
Dim dept As String
Dim db As DAO.Database
Dim rst As DAO.Recordset
Dim qd As DAO.QueryDef
Dim varResults
Dim oMessage
Dim sQueryName As String
Set db = CurrentDb
mdbname.[Form_Name].Department.SetFocus
dept = formname[Form_Name].Department.Text
sQueryName = "Query_Name"
Set qd = db.QueryDefs(sQueryName)
' set up input field for query
qd.Parameters("field_from_query") = dept
Set rst = qd.OpenRecordset()
Dim recCount As Integer
recCount = rst.RecordCount
If recCount > 0 Then
With rst
.MoveLast
.MoveFirst
Do While Not .EOF
listBoxproducts.AddItem .Fields("pname")
listboxCode.AddItem .Fields("pcode")
listboxPrice.AddItem .Fields("pprice")
.MoveNext
Loop
End With
rst.Close
Set rst = Nothing
Set qd = Nothing
Set db = Nothing
Jan 13, 2009 | Computers & Internet
I installed DB2 in my laptop . then i go to all programs->DBCOPY1(default)-> command line tools -> command editor then write down query to create a table but i cant build it it is showing CREATE TABLE...
Before you create a table you need to:-
1. create a database
2. create a username and password or use the admin generated userid
3. connect to the database
you can then create a table and use the database
Please post if you do not know how to do this and i'll give you some links
Dec 05, 2008 | IBM DB2 Connect Enterprise Edition for PC,...
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Vb project
One of three ways:
1 make the table using vb creating a Bload screen.
2 using the visual data manager.
3 import a windows access or excel data base table.
Try the data wizard, easiest to use and U can program the program to manipulate the data in the tables.
May 29, 2008 | Computers & Internet
Visual Basic 6.0
1. IDE is Integrated Development Environment
2.With VB 6, one can develop applications with feature rich GUIs (Graphical User Interface). Many varieties of general purpose software can be created with little effort, including, but not limited to, image editing software, text editor and database applications.
3.Windows Application Template
Used to create Windows-based applications that run locally on users' machines. You can build anything from a simple single-window tool like Windows Calculator to a complete application with multiple windows and advanced capabilities.
Class Library Template
Used to create reusable classes or components that can be shared with other projects.
Console Application Template
Used to create command-line applications, programs that run from a Windows command prompt and have no visual interface.
My Movie Collection Starter Kit Template
Used to create the pre-built My Movie Collection sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
Screen Saver Starter Kit Template
Used to create the pre-built Screen Saver sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
4.FormShaper lets you change the shape that windows draws your forms. You can have rectangles, rounded rectangles, ellipses, polygons and any combination of the above! Even save the shapes to a file for use in other projects! See readme.txt in the zip file for more details
5.Description
Used at script level to force explicit declaration of all variables in that script.
Syntax
Option Explicit
Remarks
If used, the Option Explicit statement must appear in a script before any procedures.
When you use the Option Explicit statement, you must explicitly declare all variables using the Dim, Private, Public, or ReDim statements. If you attempt to use an undeclared variable name, an error occurs.
Use Option Explicit to avoid incorrectly typing the name of an existing variable or to avoid confusion in code where the scope of the variable is not clear.
Feb 20, 2008 | Computers & Internet
SQL Server 2000
An easy way to transfer objects (tables, user defined functions, stored procedures, etc.) is to use Enterprise Manager's "Generate SQL" feature. Use this process at your own risk. Doing it wrong could mess up your existing database.
1. In Enterprise Manager, right-click on the old database and choose "All Tasks" then "Generate SQL Script".
2. In the dialog that comes up, click "Show All" then select the checkboxes for "all stored procedures" and "all user defined functions". (You might also want to check some other boxes, depending on your exact situation.)
3. Click the "generate" button and save the script that it creates.
4. Run the script in the NEW database.
If you run the script in your OLD database, it may destroy your objects, and that would be very bad. Make sure you run the script in your NEW database. (While we're on this subject, it's a good time to mention that you should back up your database before you start this process, and you should make changes to a test system before migrating it to production.)
That should move your stored procedures and user defined functions over.
You can use a similar process to move tables, views, users, and other objects over as well.
Jan 17, 2008 | Computers & Internet
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
