Question about Select Brands Matsonic mATX 800Mhz s775 P4, VGA/Audio/Lan DDR400 SATA RAID 0, 1, 3PCI 1 8X AGP, 8X USB2.0(BRAND NE... (MSP4M800M) Motherboard
Different brand of RAM used problem
Is it ok to use different brand of RAM on the same PC? I was using "eRAM" and added "Kingston", but it does not seem to work! There are both DDR400 PC3200, 184 Pin DIMM RAM. Is there any known problem for Matsonic MB with Kingston RAM?
  • 71 Answers
Unfortunately not all ram, even if its the same speed, works on all motherboards. my suggestion is to see which one works by itself by putting just one of the modules in. then get a matching one of the one that works. if they both work individually, then i would go with the kingston, it is the better RAM. hope this helps.
Posted on Sep 15, 2007
SOURCE:
Need install more ram
Hi.
you have to use DDR 2 RAM with 800 mhz .
you`re Manuel say`s maximum is 4GB.
maybe a BIOS-Update can help to use more than this 4 GB.
otherwise you need a new Motherboard to fix this.
lg Gue.
Dec 29, 2013 | Shuttle XPC PC Desktop
Acer Aspire M3400 Desktop PC. Memory Upgrade Issue
please check the memory timing settings. if your mixing up ram they may not have the same memory timings and require you to go either higher or to the supported settings that either memory can use. for example if corsair runs at 8-8-8-14 and kingston runs at 10-10-10-16 then you will need to bump the settings to 10-10-10-16 since the computer is trying to set the timings for kingston to 8-8-8-14 which it does not support.
Feb 18, 2012 | Acer Aspire M3400 PC Desktop
Dear Expert, I have Asus motherboard P5S800-VM. Now,There is 1.5 Gb ram(512MB+1 GB).If I plug 2Gb ram (1+1), then PC is working very slowly.What can I do for this problem . ram:2x1Gb Kinsgton thanks
First verify that you are using the proper speed of RAM. Second, check the BIOS and make sure that recognizes the RAM you have installed. Sometimes you have to manually set the RAM size in the BIOS in order to get it to work. Finally, I have had several issues with Kingston RAM on different motherboards even when it is the proper type so you would want to try a different manufacturer.
Jul 08, 2011 | ASUS P5S800-VM Motherboard
Gateway mx7118 wont start wirt added ram. I want to add a 1gb stick od ddr2700 ram but it wont start with the mamory installed, just sits there with a blinking cursor
If you are using 2 different types of ram (from different mfg.,same brand may not work if made to diff specs) it will not work.
Mar 02, 2010 | Gateway MX7118 Notebook
Gateway memory problems mx3225, I can not upgrade from 256 m to 1G have tried to different modules same result black screen
1GB RAM for Gateway MX3225 (DDR2) Memory 1GB 533MHz DDR2-533 , PC2-4200, 200p SODIMM, 1.8v, CL=4, 128Megx64 - Kingston Brand works.
Jul 19, 2009 | Computers & Internet
Lg ls50a laptop cost of 1gb ram
Go to the manufacturers website and see how much it costs there. It's good to get your parts from the makers so you know for sure that it will fit and is compatible.
Jul 08, 2009 | Computers & Internet
Right memory for Dell Inspiron 1300 ME051 Intel Celeron 1.60 GHz, 533 Mhz
This chip will not work in your machine. You machine takes the PC4200 or 533mhz memory, the kingston chip you listed is 667mhz or PC5300. A very useful site for memory configuration is patriotmem.com
Jul 19, 2008 | Dell Computers & Internet
Right memory for Dell - Inspiron Laptop with Intel® Pentium® Dual-Core Processor T2390
Cannot upgrade Memory on Compaq Presario 2110US
hi Rileysue ... what is the model of your HP? ... the ram modules generally have to match each other ... brand should make no difference at all .... start by removing all of the old and add one stick of the new ... you may also have to go into the BIOS each time and verify the change in ram size ... then add the next stick and so on...
Mar 30, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Open Questions:
\Q;- RICOH PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This RICOH PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 RICOH PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the RICOH PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, RICOH PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH PRINTER USA Calling RICOH PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH PRINTER USA's phone numbers against each other. Contacting RICOH PRINTER USA in General While [+I8OO-8O3-1O69] is RICOH PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach RICOH PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH PRINTER USA.
Oct 18, 2019 | Ricoh Computers & Internet
\Q;- KODAK PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KODAK PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KODAK PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the KODAK PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, KODAK PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK PRINTER USA Calling KODAK PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK PRINTER USA's phone numbers against each other. Contacting KODAK PRINTER USA in General While [+I8OO-8O3-1O69] is KODAK PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK PRINTER USA.
Oct 18, 2019 | Kodak Computers & Internet
\Q;- TOSHIBA PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This TOSHIBA PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 TOSHIBA PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the TOSHIBA PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, TOSHIBA PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA PRINTER USA Calling TOSHIBA PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA PRINTER USA's phone numbers against each other. Contacting TOSHIBA PRINTER USA in General While [+I8OO-8O3-1O69] is TOSHIBA PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA PRINTER USA.
Oct 18, 2019 | Toshiba Computers & Internet
See all Select Brands Matsonic mATX 800Mhz s775 P4, Questions
Select Brands Matsonic mATX 800Mhz s775 P4, VGA/Audio/Lan DDR400 SATA RAID 0, 1, 3PCI 1 8X AGP, 8X USB2.0(BRAND NE... (MSP4M800M) Motherboard Logo
75 people viewed this question
Top Select Brands Computers & Internet Experts
Ekse
Alun Cox
Are you a Select Brands Computer and Internet Expert? Answer questions, earn points and help others
