Question about GE JE1540 Microwave Oven
Running with door open
Microwave running with door open then you close it and it stops running
  • GE Master
  • 9,098 Answers
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. You can find helpful exploded view diagrams and order parts by entering your model number here: If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa:
Posted on Sep 22, 2007
My microwave keep working when I open the door and it is stopping when I close the door.Then working normal but I cannot keep my door open, it keeps running. What can I do??
First, It is very very dangerous for a microwave to run with door open. The door is also a shield to protect you from the microwave radiation. There should be a safety interlock to prevent this from happening. DO NOT USE the microwave! Seek out professional repair or replace the unit.
May 20, 2015 | Microwave Ovens
Runs when door is closed,stops when open!Checked the three door switches;all good.The mw is 5 years old so anyone have suggestions as i would be thanking U in advance
It is possible that a relay on the control board has stuck in the closed position. You can try tapping the relays on the main control board and this sometimes breaks them free. It still may be one of the door switches but I would suspect the control board or possibly a stuck start pad on the touch panel.
Apr 24, 2015 | Cuisinart CMW-100 Microwave Oven
Why microwave won't stop running unless door is open ?
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
Aug 16, 2014 | Whirlpool Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
Microwave Ovens Logo
129 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
