Garden Logo
R Morse Posted on Sep 14, 2013
I have a Stanley SD350 garage door that will not open all the way. There are two seams in the support rail and at each seam the threads on the screwdrive are missing so I think that is by design. The door opens past the first seam just fine, but stops at the second seam which is about 2/3 of the length of the screwdrive. How do I fix this?
Don Patton
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jan 10, 2014
Don Patton
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
7443
Points
36
If you are talking about a garage door opener then you should disengage the safety lever so the door will go-up and down with little effort if it doesn't then you need to adjust the door untill it does. Hope this helps
1 Related Answer
Anonymous
  • Posted on Dec 10, 2011
SOURCE: I have a stanley SD350
Mine is doing the same thing. Did you get your problem resolved and if so what did you do? Thanks
Stanley garage door opener model 440. need a manual
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
https://www.manualslib.com/products/Stanley-U-Install-3760134.html
If you can identify the model number, it may be possible to locate a manual from 1997 using the internet with http://www.google.com
According to one of the web sites above, "Stanley stopped making garage door openers and gate operators in 1997. Spare parts can be difficult to find however original and compatible remote controls are still widely available, most of the remote controls used by Stanley were manufactured by the Linear corporation.
Stanley made garage door openers for other companies and many parts are interchangeable some of the brands they manufactured for are Vemco, U-Install, Quiet Glide, Light Maker, Home Innovative, Whistler, Popular Mechanics, and Secure Code."
https://www.justanswer.com/home-improvement/7enbn-stanley-garage-door-opener-model-440-51-garage-two.html
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
1helpful
Manual for overlocker
Looks a lot like my Juki MO-104. To thread this thing remember this sequence.
Upper Looper, Lower Looper, then needle(s)
Open the front panel to get to your lower loopers and I think there should be a threading diagram inside on the door. Then always have test fabric that matches your project fabric. Sew a 3 " seam, check the seam.... adjust tension. If you want to get really good at seeing what's what in tension is doing thread each thread with a different color. To do your test stitches.
I've not found a manual that doesn't cost.
I have just been given a huskylock 341. The tension is off. How do I correct this?
Have you used an overlocker before? If not, I'd suggest that you obtain a user manual for it as they are completely different to a sewing machine and at some point you will need to rethread it. You can purchase one from here
http://pages.sewing-machine-manuals.com/173/PictPage/3923709707.html
This machine makes three and four thread seams, which is a combination of two needles and two loopers. For the three thread seam you can use either the left or right needle which gives you different sized seams. For the four thread you use both needles, one goes through the middle of the seam and the other is on the left side securing the seam. tally_girl_70.jpg On most overlockers you are able to move the cutting blade too and this will reduce or increase the amount of fabric being trimmed from the right side.
This page http://sewing.about.com/od/sergersoverlock/ss/serger.htm will give you some general information on sergers/overlockers too.
So adjusting tension is a matter of changing the tension on the top and lower looper threads to close up against the cut edge, or moving the blade over to make the seam a little wider or narrower. You may also need to finess the left needle tension so that the seam doesn't pull apart, I always test serge two layers and then pull open from the right side and see if the needle thread is showing (it will show a little bit but you dont want it so loose that it pulls open. Only tighten the needles in very small increments though, as you'll break threads and needles if you turn them up too tight.
Hard to explain without seeing what your machine is seaming now. But as a rule of thumb, start with all four tension dials (or 3 if doing a three thread seam) on 5. If the tension dials are correctly calibrated then this should give you a pretty good seam. You may wish to lengthen the stitches, I usually work with stitch length of 2.5 (same as your sewing machine stitch length) Stitch length will be a dial on the right side beside the flywheel or in front of the blade area. The blade adjustment should be a little knob near the blade area too. There will be a lower fixed blade and a moving upper blade which sits against the lower one, they work like scissors to trim the fabric. So to adjust the blade, you will need to take the pressure off the upper blade, then wind the knob to move it left or right.
Different weights of fabric will behave differently on the overlocker so you do need to adjust tension for each new project. For example, if seaming a jersey knit you'd use a four thread seam, this gives elasticity and strength and you can join two garment pieces with this seam. You'd probably make a 6mm or 7mm wide seam, the left needle will secure the fabric and the loopers will encase the fabric smoothly while the right needle secures them and gives extra strenth to the seam.
But on organza for example, I would make a very narrow three thread seam using the right needle as the organza will roll inside the overlocking if you cut the fabric too wide.
And on something like curtains I would neaten the edge with a wide 3 thread seam using the left needle to get a very wide seam, the fabric wont roll so you'd need to loosen the two loopers a little to smoothly encase the cut edge.
tally_girl_71.jpg For example, on this image above you can see that the looper threads are laying a little off the edge of the fabric in places, particularly the lower looper, (the side that looks like Y's where you can't really see the middle needle thread), so I would tighten the lower looper about .5 on its dial, then test again.
I hope that this makes sense to you, you will need to test serge, and adjust one dial at a time, test again and look at the result, then maybe adjust another thread until you are getting a smooth looking seam.
Garage door door will not open or close
LOOSE BELT FULLY AND TRAY TO SEE IF THE MOTOR WORKS WITHOUT BELT IF SO INSTALL BELT AGAIN THIS RESOLVE THE PROBLEM
Bernina 334DS serger - RH needle tacks lower looper into seam
You should take it for service. It could be slightly out of time.
May 26, 2017 • Necchi 6011
Garage door opener
You need to re-align the drive belt - it thinks it is in the raised position, with the door on the ground.
Top Garden Experts
Jay Finke
Jay Finke
john h
