Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel AD55 Dryer trips breaker
F&P AD55 dryer trips safety switch breaker when turned on. I removed the heater element and thermostat and motor runs fine (ie does not rip breaker). What resistance should heater element be? When I went to buy a new heater element at the local F&P dealer - they had to look it up and order it. He said they almost never blow. Can they short to earth?
Any ideas?
Pete
4 Suggested Answers
  • 2468 Answers
SOURCE: I have a Fisher and Paykel AD55 dryer. When I turn
if it tries to start when you push the start button and quits when you release it,the belt is broken,theres a belt sensing switch by the motor so when the belt breaks the unit wont stay running
Posted on Oct 02, 2010
sonicboomele
  • 1557 Answers
SOURCE: how do I replace the main bearing in an AD55
not that hard you take the back of then take the barrel out punch out the 56833 strem grease bearing then replace with new one and re assemble just note the way the driver belt comes of there tricky to put back on
let me know how you went
Posted on Dec 31, 2010
  • 3074 Answers
SOURCE: How do take my fisher
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Posted on Apr 15, 2011
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Dryer won't heat at any setting.
Check for tripped twin breakers in the house electrical panel--push off, then on. If no help, then likely burned out heater element or open thermostat that controls the heater. These parts are usually behind the main drum and require removal of the drum to access. Hope this helps!
Jun 27, 2010 | Fisher and Paykel DE06 Electric Dryer
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
AD55 Dryer makes a dual clunk like it is out of round.
Run the dryer and look through the front door and watch for if the drum is running out of round at the back. The AD55 only has one bearing and this is at the rear of the drum, the front of the drum is supported by 6 plastic tabs that it glides over. These tabs are reversible if they become worn and a drum bearing assembly kit is available from Fisher & Paykel. For a detailed drawing of the dryer contact your Fisher & Paykel service center and they will email you a copy.
Mar 02, 2010 | Fisher and Paykel Dryers
Fisher paykel elec dryer not heating
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 02, 2009 | Fisher and Paykel DGGX1 Electric Dryer
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
My fisher paykel DEGX1 won't heat up. everything else works fine.
If you have the same I do then it's the circuit breaker on the heating element. You have to take the front of the dryer off: Two screws on the top under the caps. Then lift the top alittle and you'll see the two screws on the front top sheet metal. The front then can be removed by pulling each side out and forward. The orange button is all the way at the bottom. Push and you'll hear it click.
Mar 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
I have a fisher paykel dryer about three years old that now does not heat up
The video below explains how to test your dryers heating element and how to open it up.
Feb 01, 2009 | Fisher and Paykel DG05 Gas Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
180 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
