Question about Kicker Solo-Baric S8L7 Car Subwoofer
On the kicker S8L7 4ohm dual voice coal do you hooki neg to pos diffrent coals
    Problem Solver:
  • 10 Answers
Check out this link below an select your amp classification (ie. mono, 2 channe, 4 channel) then select how many subs you are goin to run and the sub classification..
http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html
Posted on Apr 04, 2010
    Problem Solver:
  • 9 Answers
Http://kicker.com/dvc_wiring , this should help you.
Posted on Jul 05, 2009
I have two kicker cvr dual voice coil 4 ohms to a
what about the remote power wire from the radio? 2 channel or four channel(amps)? are the speakers running parallel or in series? are you using a mono block? or an EQ?
Oct 13, 2014 | Car Audio & Video
How to make a kicker cvx 12 inch dual coal subwoofer 4 into a 2omh
Ok, follow closely. This is called the parralel set up. This is the easy way.
1. Identify the possitive on your amp or box you are installing in. Run the possitives of both voice coils to this. (yes, you will need two lengths of speaker wire)
2. Identify the negative on your amp or box you are installing. Run the negatives of both voice coils to this
How to figure ohms R1 x R2
R1 + R2 So your load 4x4=16 divided by 4+4=8 16/8 = 2
Ohms loads seem difficult at first, but they are easy if you think about it. We are taught in school that parallel means side by side, right. The same applies for wiring. A parallel set up means that both voicecoils are receiving the power from the source. If you look at your wires when you are done, both wires are "side by side", hence parallel. Now series means going from one thing to the next thing, right. So it is in wiring. Power would go from the source to the positive of one voice coil, the from the negative of that same voice coil to the positive of the next voice coil, then from the negative of that voice coil back to the source. I hope this helps
Aug 14, 2011 | Car Audio & Video
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg.to neg. then to your amp.
Jan 18, 2010 | Kicker CVR12 Car Subwoofer
How can you make the splx subwoofers into 1 ohm
Dual what??? the only way to do that is to have a dual 2ohm sub and run in parallel. pos to pos, neg to neg. Parallel cuts the ohms in half and series doubles it!
Sep 06, 2009 | Car Audio & Video
Bad sound while playing at low volume, tested both voice coils and they are both are around 4 ohm.
do you have it wired down to 0 ohm or 2ohm if u have a mono block amp wire it to where a pos. from one side goes to a neg on the other side and then use a pos an neg from diff sides coming from amp
Jul 30, 2009 | Kicker Solo-Baric L5 Car Subwoofer
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Kicker Solo-Baric S8L7 Car Subwoofer Logo
101 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
