SOURCE: Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
SOURCE: my rolex has stopped working its a ladys datejust
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
