Northwestern Bell Big Button Plus 20200 Corded Phone Logo
A
Anonymous Posted on Sep 14, 2013
Hard of hearing and visually compromised has difficulty using the memory keys
I got a 01 grand caravan that I start with a screwdriver I bought a universal key switch that has 3 terminals the ignition switch has 6 what 3 do i use
It would be infinitely better to repair or replace the broken lock or stick with the screwdriver.
Fitting a universal switch intended for ancient cars or mowing machines isn't advisable and probably hardly possible without making some large compromises. It would be a good idea to study a wiring diagram to help ensure you make the best compromises.
How do I get a visual on the netflix movie that is playing? I can hear it, but the screen is white.
HI Jennie
If your using a recent Mac with say Maverics OSX then it may be in an off screen window.
Try these Keys
Ctrl & Page up (Arrow Key).... then Choose Movie Window
Ctrl & Page down (Arrow Key)....
The Settings for this are kept in Settings / Mission Control
I think this will allow you to see the offscreen alternate windows.
Netflix is an on line Internet player from a Paid service.
I don't use the same method or app as you so I'm not sure this will work. I use an Application to play movies from my external hard drive and I get the same off screen window that you seem to be describing.
Good Luck
Trevor
Other Notes:
I use VLC to play all my movies of my hard drive (a free download & it plays every codec type avi, mp4 etc) I keep the Icon for VLC in my bottom dock.
When I double click the VLC icon in the dock the window switches to the current movie playing,
If your using a different movie player program then just double click it's icon in the bottom dock. (e.g. Quicktime Player)
If you do switch to VLC then use the Cmd I (Info) on each type of movie (e.g. .mp4) In the Cmd I , Menu , choose "Open With" and select VLC as the preferred player (after you have installed VLC of course) then click the "Change All" button.
From then on all MP4's movie types will be played by VLC.
Describe the requirements of foxpro in terms of hardware and memory
System RequirementsTo install Microsoft Visual FoxPro 9.0, you need:
Minimum Requirements Processor
  • PC with a Pentium-class processor
Operating System
  • Microsoft Windows 2000 with Service Pack 3 or later operating system
  • Microsoft Windows XP or later
  • Microsoft Windows Server 2003 or later
Memory
  • 64 MB of RAM minimum; 128 MB or higher recommended
Hard Disk
  • 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
Drive
  • CD-ROM or DVD-ROM drive
Display
  • Super VGA 800 X 600 or higher-resolution monitor with 256 colors
Mouse
  • Microsoft Mouse or compatible pointing device
1helpful
What are the hardware requirements for foxpro?
  • Processor: Pentium-class processor
  • OS: Windows 2000 with SP3 or later, Windows XP or later, Microsoft Windows Server 2003 or later
  • Memory: 64MB of RAM min., 128MB recommended
  • Hard Disk: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Drive: CD ROM or DVD-ROM drive
  • Display: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Mouse: Microsoft Mouse or compatible pointing device
from: http://msdn.microsoft.com/en-us/vfoxpro/bb190292
3helpful
I wanna format my phone.. its a samsung corby txt..
Hello
If you are facing any difficulty in your phone, then go for hard reset instead of formatting.
Please consider using the below codes in order to have the phone restored to factory settings and hence get the present difficulty experienced solved.
"Remember: before entering the following code, make all of your contact's and messages' backup to your memory card and remove the memory card from your cell phone, and then enter any of the following codes"
*2767*3855#
*2767*2878#
Well, I am new to fixya, so please don't forget to appreciate the solution.
Thanks
Jan 27, 2011 • Cell Phones
1helpful
How to install foxpro
You can install this version of Visual FoxPro from a CD-ROM or anetwork to a local hard drive. You must install Visual FoxPro on alocal drive, not a mapped drive. There is no other preparation requiredbefore installing Visual FoxPro. You must have administrator privilegesto install Visual FoxPro. It is recommended that you run withpower-user privileges to use all the provided tools effectively.
Youcan safely install or uninstall using Visual FoxPro Setup. If you areupgrading Visual FoxPro, you must first uninstall the previous versionof of the program. Though both versions of Visual FoxPro can exist onthe same computer, you cannot install the current version of VisualFoxPro in the same directory as the previous version.
If you planto publish XML Web services using Visual FoxPro, you might want to setup Internet Information Services (IIS) on a Windows 2000, Windows XP orWindows Server 2003 computer. Refer to your operating systemdocumentation for instructions on how to set up and configure IIS.
030c41d9079671d09a62d8e2c1db6973.gifNote VisualFoxPro setup no longer installs any Windows operating system ServicePacks or versions of Internet Explorer. It is highly recommended thatyou install the latest versions of these components before installingVisual FoxPro. Additionally, Visual FoxPro 9.0 is supported only onWindows 2000 Service Pack 3 or later. For details about installing thelatest Service Pack, visit the following Microsoft Web page at http://www.microsoft.com/windows2000/.
Full installation includes all Visual FoxPro program files, online help, and samples files.
To install Visual FoxPro
  1. Quit all open applications.
    030c41d9079671d09a62d8e2c1db6973.gifNote Ifyou use a virus protection program on your computer, override it orturn it off before running the Installation wizard. The Installationwizard might not run properly with virus protection turned on. Afterinstallation, be sure to restart your virus protection program.
  2. Insert the Visual FoxPro CD.
    The Visual FoxPro Setup start page appears automatically.
  3. Click Install Visual FoxPro to launch Visual FoxPro Setup.
  4. To determine if you need additional components, click Prerequisites to display any necessary components.
  5. Click Install Now! to install any new components. If Visual FoxPro Prerequisites needs to only update components, click Update Now!
  6. You might need to restart your computer. When finished, click Done.
    Visual FoxPro Setup reappears.
  7. To continue installation, click Visual FoxPro.
  8. After accepting the End User License Agreement and entering the Product Key and your name, click Continue.
    030c41d9079671d09a62d8e2c1db6973.gifNote Visual FoxPro cannot be installed on a mapped drive. You must install Visual FoxPro on a local drive. Do not attempt to use the Map Network Drive functionality in Setup.
  9. On the Options page, select the features you want to install and click Install Now! to continue.
  10. When finished, click Done to return to Visual FoxPro Setup. Click Exit to return to the Visual FoxPro Setup start page.
Ifyou uninstall Visual FoxPro while the previous version of Visual FoxProexists on your computer, certain shared registry keys used by theprevious version of Visual FoxPro are removed. You must reinstall thesecritical shared registry keys.
If you run Visual FoxPro fromthe Start menu, Visual FoxPro Setup automatically reinstalls thesekeys. If you start Visual FoxPro using other means, such as running theapplication executable directly, the setup program does not startautomatically. You should use Add/Remove Programs in the Control Paneland the following steps to reinstall the registry keys manually:
To manually reinstall Visual FoxPro 9.0 registry keys
  1. From the Start menu, click Control Panel.
  2. Click Add/Remove Programs.
  3. Click Change/Remove for Microsoft Visual FoxPro 9.0.
  4. Click Visual FoxPro and Repair/Reinstall.
Good Luck
Frigidaire micro plmv169dcd not working
test it with a meter it has a small wire inside and, sometimes can not be visually checked
DISPLAY NOT VISUAL
formating your phone may fix the problem. Heres how you can format your phone
Heres how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
before formating make sure that you copy all your contacts, messages, calendar, and each and everything in your memory card. And dont forget to remove your memory card and fully charge you phone before formating.
Win98
Mada, Are you asking if it is hard to install W98 or are you haveing problems? Its not too hard, however, W98 is no longer support my Microsoft which means no more updates. If this is not connected to the Internet that probably isn't a big deal for simple computing work. If you do expect to connect it to the Internet the lack of updates will put you at severe risk of compromise. If you are having some other difficulty please post the exact issue, problem or error message.
Top Northwestern Bell Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
