Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
My I Mac doesn't recognize the WD 1 tB external hd anymore
It wont shw up and is making strange noises
  • rpbmd May 09, 2009
    my mac never recognized a new 1TB My Book. The old 500 MB My Book  works fine.
SOURCE: LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Posted on Oct 04, 2008
SOURCE: My MAC won't recognize my WD 80 GIg External HD
Some computers (especially Mac laptops) don't send enough power through the USB port to power a passport, so you need to get an extra power cord, one that combines 2 USB ports into one to get a little extra juice. Wish I could give you a website where you can buy that extra cord but I am currently looking for one myself at this moment in time.
Posted on Nov 22, 2008
Suricatta
  • 92 Answers
SOURCE: WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Posted on Jun 24, 2009
bob_computer
  • 3153 Answers
SOURCE: my mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 31, 2009
bob_computer
  • 3153 Answers
SOURCE: I have a WD My Book 1 TB external hard drive. It
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly. 5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 17, 2009
My 1 tb wont work on my computer anymore i was using it one day and then it just goes off and shows up in my computer to eject but wont open or anything
Please check your USB ports and make sure that there is no shorting or over current.Usually external Hard drives gets fused under the above circumstances.Please check on other USB ports or another PC.If it doesn't responds please contact your nearest service center and ask them for a data recovery.It won't come under the warranty claim if the damage is severe.
May 29, 2011 | Western Digital 1TB My Passport Essential...
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
The hard disk inside it doesn't responds to the controller - hardware failure, the disk has failed.
Nothing can fix that, your unit is truly dead and you need a new one.
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
OS whont start whit WD 1 TB external drive.
You need to set your boot sequence in the BIOS so that it does not include external drives. Basically your computer is trying to load Windows from the external drive instead of its own internal one.
Your motherboard manual is going to help, if you can't manage it by yourself give me a link to your manual or tell me the model of your motherboard and i will show you what you need to change.
Oct 03, 2009 | Western Digital MyBook Studio 1 TB USB...
My mac won't recognize my wd hd anymore
Aug 31, 2009 | Western Digital My Book Essential 500GB...
External WD my book 1T want boot on Mac or PC & makes click noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 07, 2009 | Western Digital MyBook Studio 1 TB USB...
WD 1tb external drive
I got the exact same problem...I don't care much for the HD compared to the data on it...Some tried to format it as advised and it does not solve the issue...I ran the lifeguard diagnostic and it passed successfully....Very strange !
Oct 30, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
1,079 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
