Question about HP Compaq 8510w Mobile Workstation KA457UAABA PC Notebook
Cannot change my DVD region on my laptop.
Unable to watch region 2 etc regions and won't allow me to change the region. I'm running on Windows XP
I inserted a dvd and it keeps telling me "this dvd is not formatted to play in this region." how do i get it to work
Go to the driver or tools option and make sure the box for playing all regions is checked.
May 25, 2010 | Compaq (158165-001) DVD Drive
Laptop dvd drive region locked in R1, need to be mostly R2
keep in mind you can only change the region 5 times and cannot change it anymore after that (regarless to windows reinstallation , its a hardware thing) you might wanna consider purchasing "dvd region free" or use a 3rd party region free firmware to bypass that
dvd region free - http://www.dvdidle.com/dvd-region-free.htm
3rd party firmware - http://www.rpc1.org
Dec 24, 2009 | Computers & Internet
I CANT CHANGE THE REGION ON MY DVD, although I have 1 change left
you can flash the drive with region free firmware (best option if you know what youre doing)
you can reinstall os giving you extra tries.
or you can use a program called any dvd(free)which enable you to watch any region (safe)
flash is best if youre not sure or cant find software let me know and give your dvd details(firmware)
eg freecom dvdrw 523252
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Changing the DVD Region code
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
Jan 26, 2009 | Microsoft Windows XP Professional for PC
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Region code changes
You can always try the program called DVD Region Killer.
DVD Region Killer is a simple, small and easy-to-use software application that enablesyou to play DVD titles made for different regions on your PC, without the hassle to switch the region of your Windows operating system and / or the region of your DVD player software back and forth.
DVD Region Killer can reside unobtrusively in your system tray and you can access it easily only when you need it.
Jan 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Go to My Computer, right click on the DVD icon, select Properties, choose the Hardware tab and DVD regions will be selectable there! Steve
Dec 12, 2008 | Microsoft Windows XP Home Edition
Laptops travel, are they region free ?
The DVD wont need a region setting.
Use a dvd player like videolan which is free and will play all regions all dvds etc. In fact its a great player. download it here and hey presto!!
http://www.videolan.org/
Nov 04, 2008 | Microsoft Windows XP Professional With...
since the changes remaining is set to 0, sorry to say that you cna no longer change this to a different regional setting, unless you reinstall the OS,
chances are you have selected the region previously, or somebody else.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
or you can install one of this program:
The region can only be changed five times, before its set permanently.
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
hope this helps dont forget to mark my solution pls
Aug 07, 2008 | Microsoft Windows XP Professional With...
Blueray
You can always invest in the program called AnyDVD. It can be found at
http://www.slysoft.com/en/anydvdhd.html
This should solve your region issues with the BlueRay disks. Run this program, then insert your movie into the dvd player, and watch the movie play. Take care and enjoy!
Aug 02, 2008 | Acer Aspire 3680 Laptop
HP Compaq 8510w Mobile Workstation KA457UAABA  PC Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
