Question about Saeco 30511 Espresso Machine
HELP FROM EXPRESSO NEWBE
I bought a used machine & know nothing about it or any other expresso machines. I made a cup of expresso & water & grinds flowed out all over the place. Is there somewhere I can get a manual for this machine? Or some instructions? In reading some of the comments I'm assuming I might need to change all the gaskets & give it a good descalling everything else seems to work properly. Any help would be greatly apreaciated. C4es
  • graemedudley May 11, 2010
    I also have this machine - I also need a manual etc Can either of you folks help me out now, that is if you solved the problem yourselves Cheers Mariah, Darwin
  • 515 Answers
What kind of machine do you have?
Posted on Jul 12, 2008
SOURCE:
When I just have water in the portafilter it runs through fine. When I put the expresso in it clogs and expresso will not flow through.
No solution here. Utopia directions say to only use MEDIUM (drip) grind. Ain't it awful? I prefer ultra fine grind, frankly muddy coffee.Deb
Jul 10, 2011 | Starbucks Barista Utopia
We got a gagia expresso color machine recently. We used it for a week and now the machine is not is not dispensing expresso. The machine makes sound but no expresso comes out. The tank has enough water....
Your are propably need to prime the machine. This mean that air blocked in the machine and need to get out and fill all pipe system with water.
To do this you need to warm up the machine and turn the hot water knob so you will get one cup of hot water from the steam wand. After that try to get some water from the coffee head without any coffee in the filter handle. Now the machine is ready for coffee again. You will need to prime the machine very often so try to remember the procedure. This will happen again usually after you use the steam process and this normal for your machine.
http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime
May 01, 2011 | Gaggia 102534 Espresso-Color...
My palazzo only works when i press the button for expresso?it doesnt work when i push the button for the bigger cup ?
HI
If it works for espresso, but it doesn't work for the large cup, try holding the large cup button down and keep it down. Let it go through the grind, the clicking, and if it starts to dispense coffee , still don't release it until you have the desired amount in your cup. Then release it.
If one of the coffee buttons is held down for 3 seconds or more and then released, the water program goes back to zero. No water. You have to reprogram the button like we did above.
Nov 08, 2009 | Solis Palazzo Espresso Machine
My Krups 4000 Expresso machine while still heating up is not putting out any coffee(expresso)
I had the same problem. The issue was that the machine needed a clean to dissolve Calcium build up from the water. I used a commercial cleaner available at my local supermarket but have since used white vinegar and get just as good results. I just put about a cup of white vinegard in the water haopper and run the machine without the group attatched. I run the steamer wand and then put another cup through with the group attatched . I then rinse a few times with fresh bottled or distilled water.
Oct 07, 2009 | Krups XP 4000 Espresso Machine
Vev Vigano Carioca Nero Espresso Maker..what kind of grind to use
Use fine grind for espresso, darker roasted bean blend on Italian roast style are better, they are stronger and oily, perfect for expresso machines like this.
One of the best available here is this: Lavazza Qualita Rossa Ground Coffee, great brew on Moka style espresso machines.
Feb 16, 2009 | Vev Vigano Carioca Nero Espresso Maker...
Water on top of the filter after brewing
my experience with this machine is that this varies greatly with the type of beans you use. I would experiment with a few types of beans, roasts, and you might get lucky.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Inoperable expresso machine
Make sure the magnet in the water tank float up to the top.
Try to make a full cup of water (Tea).
Let me know if i can help you more
Best regards
/Mirran
Sep 08, 2008 | Saeco Incanto Classic Espresso Machine
Saeco 30511 Espresso Machine Logo
146 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
