Question about Exercise & Fitness
Machine does not register when rowing
Since I moved house (it must of got damaged in van!) my rower hasnt worked properly. The electronics are still on...but when you start to row it doesnt register! So it all just stays at 0. Can i fix this???
  • 4 Answers
You most likely moved or damaged the senser under the seat check if the wire is loose or damaged the the senser it in the center of the bottom side of the seat Good luck
Posted on May 11, 2009
Motherboard just beeps - no display
Unfortunately stuff today is produce to replace, not fix and I guarantee you that Reebok does not actually produce a rower but instead just leases out it's name. So you might want to try to find out who actually makes the product, there may be some information on the machine itself.
Also, here is a link for http://www.ebay.co.uk/bhp/reebok-rowing-machine ebay search of reebok rowers, you may be able to find a second one as parts for cheap instead of buying a new display or motherboard.
You could also take the display unit to an electronics repair shop and have them troubleshoot and fix it.
Apr 13, 2014 | Nordic Track Exercise & Fitness
Pulley on a rowing machine
return spring broken replace..
very common problem
Jan 15, 2013 | Body Sculpture Rowing Machine - Orange
Help with kettler Isis rowing machine
The rower has been pulled off of my kettler isis magnetic rower. i have opened it up and cannot work out how to put reattach the line. can anyone help or send me a link to show me how to do this??
Aug 02, 2012 | Kettler Exercise & Fitness
I have a Tunturi R60 rowing machine but i have lost the elcetrical lead for it, where can i get another one from?
You should be able to buy a replacement from shops such as Maplin in the UK or Radio Shack in the US. The R60 runs on 6v at .5 amp.
Feb 06, 2012 | Tunturi R60 Rower
I need an instruction manual for a motive fitness rtx8 rowing machine?
http://progressionfitness.ca/Manuals/Rowers/rtx8/files/rtx8-rower.pdf
May 14, 2011 | Computers & Internet
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
We have hardly used our C2 due to continuous house moves[purchssed new in 2005/6] went to set it up today and the screen just has a series of vertical and horizontal line and then goes blank
I to have a C2 rowing machine with a PM3 moniter which i havent used since August last year, and i decided to use it to help loose the excess Christmas pounds and the moniter sounds like it does exactly the same as your moniter with the vertical and horizontal lines then goes blank. I bought the rower new about 2/3 years ago and it hasn't been used too much.
If you find a solution to the problem please let me know thanks (jm@manx.net)
James
Nov 04, 2009 | RTO Concept2 Model D Rowing Machine with...
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 31, 2009 | Exercise & Fitness
What kinds of boats are used for rowing?
The boats (or shells) are basically of two types and reflectthe two forms of rowing---sweep rowing and sculling. In sweep rowing each rower handles a single oar (about 12.5 ft or 3.9 m long) in sculling a rower uses two oars, or sculls, (each about 9.5 ft or 3 m long). The word shell is often used in reference to the boats used because the hull is only about 1/8" to 1/4" thick to make it as light as possible. These shells are also rather long and racing shells are as narrow as possible while recreational ones can be rather wide. Most shells today are made of composite materials such as carbon fiber, fiberglass, or kevlar. A few manufacturers still build wooden boats. Each rower has his back to the direction the shell is moving and power is generated using a blended sequence of the rower's legs, back and arms. The rower sits on a sliding seat with wheels on a track called the slide. Each oar is held in a U-shaped swivel (oarlock) mounted on a metal pin at the end of a rigger. The rigger is an assembly of tubes that is tightly bolted to the body of the shell.The exception to this are some european recreational boats called "inriggers" which have the oarlock attach directly on the gunwale. The subtypes of rowing shells are classified according to the number of rowers in the shell. Sweep Boats (each rower has one oar) These shells can have a coxswain---a person who steers the shell (using a rudder) and urges the rowers on. I have included in parenthesis the symbol used for each subtype along with some dimensions and weights. Coxed Pair (2+) Two sweep rowers with a coxswain. Coxless Pair (2-) Two sweep rowers without a coxswain. Coxed Four (4+) Four sweep rowers with a coxswain. Straight (or Coxless) Four (4-) Four sweep rowers without a coxswain. Steering is usually accomplished via a rudder that is attached to a cable that is connected to one of the rower's foot stretchers (this an adjustable bracket to which the rower's feet are secured). The coxless pair has a similar type of rudder setup. Eight (8+/8o) Eight sweep rowers with a coxswain. Eights are 60+ ft (~18.5 m) long and weigh about 250 pounds (~114 kg). Sculling Boats (each rower has two oars) Only in rare cases do these boats have a coxswain. Steering is generally accomplished by applying more power or pressure to the oar(s) on one side of the shell. The hands overlap (usually left over right in the US) during part of the rowing cycle, or are always left in front of right. Single (1X) One rower or sculler. Singles are about 26 ft (8 m) long and less than a foot (0.3 m) wide. Racing singles can weigh as little as 30 pounds (~13.5 kg). There are heavier (~45 to 50 pounds), shorter and wider versions often referred to as recreational singles. Double (2X) Two scullers. Most racing doubles can be also used as a pair with a different set of riggers designed for sweep oars. When used as a pair a rudder is usually added. There are also recreational versions of sculling doubles. Quadruple (4X) Four scullers. Often referred to as a `quad' and usually has a rudder attached to one of the sculler's foot stretchers as in the straight four. Most quads can also be rigged as a straight four using a different set of riggers. Octuple (8X) Eight scullers. This is rarely seen, though is used in the UK, at least, in junior competition where sweep rowing is not allowed. Weight Classifications There are basically two weight classes for rowers---heavyweight (HWT) and lightweight (LWT). Men (M) For team LWT boats, there is a 72.5 kg (~160 lbs) individual maximum, and the boat must average no more than 70 kg (~155 lbs). Women (W) The individual maximum for team LWT boats is 59 kg (~130 lbs), and the boat must average no more than 57 kg (~125 lbs). In the US, the women have an individual max only; no average. In some regattas in the US (usually head races late in the season) these limits are increased by 5 lbs. A rowing shell is usually built with a particular weight class of rower in mind. Until just recently the Olympics effectively had only HWT classifications.
Dec 01, 2008 | Sevylor Fish Ranger 280
Exercise & Fitness Logo
1,215 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
