Question about Lucent CellPipe 20H Router
Line not in sync with specific bitrates
The cellpipe 20 H cpe is directly connected to the MDF.So there is not much copper wire involved.
- It is seen that the modem never syncs with 1088kbps (fixed and rate adaptive)
Configuration mode = 2 wire.
-It is also seen that some times modenm doesn't syc with 512, 1152 kbps etc .But by adjusting the current noise margin it is able to synchronize.
-If you connect other modem (say .. speedtouch ) the line does synchronize without any problems.
- One more question is that whether 2312 bitrate is supported for 2 wire?
Regards,
Sandeep
2 Suggested Answers
SOURCE: lucent cellpipe 20A usb modem
Hi all,
I was having the same problem with Alcatel Lucent Cellpipe modem with Vista. But now its working fine on my system. Just follow the simple steps below and you can get ur internet up and running.
1. Go to www.etisalat.ae > Customer Support > Downloads and Useful links > Modem drivers> Alcatel Lucent 20 A
2. Download and save the file on your desktop.
3. Extract all files.
4. Go to your computer's C drive > Windows > System32.
5. Copy the file "GsiDi32.dll" (DSL installer) and paste it in the folder of the downloaded modem driver. If it asks to replace, click on Replace the file.
6. Connect your modem to the computer and make sure the USB light is on.
7. Ignore the Found new hardware wizard and go to the folder where you saved the downloaded driver files.
8. Run setup.exe.
9. If it gives a dialog box of Missing Entry, just click OK and proceed with the instructions of the setup.
10. Your inetrnet will work fine once you enter your username and pwd.
Hope it works for you all.
Best of luck..
Posted on Jun 20, 2009
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
With Direct cable ,internet connection can able to get.Through DLINK router and adapter cann't get the connection.previously it was working.now it showing limited access or low connectivity.
This is most likely due to the still having the Media Access Control (MAC) address of the device that was previously connected the modem in NVRAM.
In order to clear this old MAC address, the easiest thing to do is to unplug the power cable from the modem for 15 to 20 minutes. This allows the NVRAM in the modem to clear and makes it able to accept the new MAC address of the router.
After the modem has been unplugged from the power for 15 to 20 minutes, plug the Ethernet cable of the router into the modem and plug the power cord back in to the modem. After the modem syncs back up to the network, it should add the MAC address of the WRT54GL router to its NVRAM and assign it an IP address. This should allow the router to connect your systems to the Internet.
Please be sure to rate my answer as a 3 or 4 thumbs up if you found it helpful. The 1 and 2 thumbs-up are like saying "didn't really address the problem" and "wasn't the best solution"
Feb 21, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Need a driver software for my usb modem
Driverguide.com has software drivers for all makes and models of modems. You may find you're driver for you're Lucent Asi-2000 USB WAN modem there.
May 26, 2009 | Lucent CellPipe 20A-USB (300402633)...
Lucent cellpipe 20A usb modem
Hi all,
8. Run setup.exe.
Best of luck..
Feb 03, 2008 | Lucent CellPipe 20A-USB (300402633)...
No connection...lights not flashing
check CPE. ensure cables are good, confirm LAN and NIC is enabled. confirm that nic settings correct ie linkspeed and duplex settings, uninstall and reinstall if necessary
Dec 05, 2007 | Microsoft MN-700 Wireless Router (p5308j)
Lucent CellPipe 20H Router Logo
75 people viewed this question
Top Lucent Computers & Internet Experts
D. E. Hev
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
