Question about Nokia 1110i Cellular Phone
Nokia 3100 si not charging but the charger is good
My nokia 3100 cellular phone is not charging but the charger is good.
  • 3 Answers
Just remove the charging dioid.
Posted on May 06, 2009
Nokia 6300 cherging no respons solution
Dear Brother Good Morning:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 08, 2012 | Nokia 6300 Cellular Phone
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
1600 not charging
use good charger... check charging pin on charging connector... check contact of charger connector to charger interface... if charger IC is the problem/damage pre-heat/replace...
May 25, 2010 | Nokia 1600 Cellular Phone
My phone doesnot charge. if i insert charger it shows isnot charging.
try another charger if that does not work the internal ic that tells the phone to charge is burnt out and youll have to replace the phone
good luck
May 15, 2010 | Nokia 2300 Cellular Phone
I am getting a message that the charger for the 5310 is not suppo
the charger of your phone is either beginning to malfunction or the charging port.
To know where the fault is coming from, use another charger to charge your phone and if the message still comes up, then you should know that the phone charging port is not good and needs to be replaced.
But if the message does not come up, then you need to change the charger.
I hope you got the message.
Best wishes.
Jan 10, 2010 | Nokia 5310 Cellular Phone
Nokia 1600 not charging please tel me this solusion
Check your charger. try to plug this charger in other compatible phone.if it charges the other phone, then the ping in your phone has gone bad. if it doesnt charges the other phone, then your charger has gone bad.
Nov 23, 2009 | Nokia 1600 Cellular Phone
Not charging nokia 3100 cellular phone
theres is a solution contact me.. itman_tech@yahoo.com
we unlock all kinds of mobile phones here in philippines... email me and i'll teach you on how to repair your mobile phone
Apr 16, 2009 | Nokia 1110i Cellular Phone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Power Problem with Sanyo-3100
About the only hope of repair I can see is to clean the charging/data connector with 99.9% rubbing alcohol and dry the phone out gently for a while with warm dry moving air, that might work if your very lucky. Best of luck!
Jun 21, 2007 | Sanyo SCP-3100 Cellular Phone
Nokia 1110i Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
