Question about Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook
The administrator block the internet connection.. How to enable this connection? i cant change some of the settings and it always says "you dont have enough priveledge to change them. please contact your admistrator".
  • ERIC BAKER May 11, 2010
    To change the setting's you have to be logged in as a adminstrator, are you logged in as a guest or do you an account that is limited under your logon name?
    President:
  • 2,004 Answers
If you bought the computer as used then you definately need to do a system restore to put it in factory setting. Restart and hold down the F11 function key till you hear a beep. Then select system/factory restore and don't forget to backup your documents.
That does fix all your problem as you will become the sole administrator to make and change settings.
Rate this please
Posted on Apr 16, 2009
How to turn off web services on a HP T790
You can configure the printer's Internet connection from the Embedded Web Server or from the front
panel.
NOTE: If an administrator password has been set, it will be required to change these settings. Thus,
the administrator can prevent the printer from being connected to the Internet, if desired.
? In the Embedded Web Server: select Setup > Internet connection.
? Using the front panel: press , then , then Connectivity > Internet connectivity.
The following settings are available:
? Enable Internet connection: The default value is Yes.
Change to No
Mar 20, 2014 | HEWLETT-PACKARD T790 InkJet Plotter...
IF the wps button on my westell 7500 routernhas been disabled, how can enable it again?
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Aug 12, 2013 | Computers & Internet
I cannot enable my wireless adapter.
go to start, control panel, network and internet, then double click your network adaptor (your wifi router) click properties, write down your I.P address given to you on screen. then open internet explorer, and type that I.P address into the search bar and press enter. you should now have access to the main router settings. it could be your routers wifi setting is turned off. just go through the menu and look for it, the menu depends on the router so i cant say which menu to go to, but its normally under advanced tab. dont change anything else unless your sure you know what your doing!!
Jul 16, 2012 | Acer Aspire 4235 4240 4535 4535G 4540...
I have a dir-615 router and it will not connect to the internet i have tried to reset it to factory default settings I've tried following the instructions on the website but i can't seem to get it to...
Jamax, its the Internet Service Providers (ISPs) who always provide clients with Internet Configuration settings which enables you to connect to their internet. Without such information, you can hardly connect to any internet, The settings consists of; the UserName, Password, DNS addresses among others. When you log onto your router, theres an application/system where you put all the required info to enable internet connection. If you dont have it, please get it fr your ISP and load it there.
Jun 24, 2010 | D-Link DIR-615 Wireless Router
Toshiba a75-229 touch pad don't work and wi-fi don't work no more
  • “Hi let’s see if we can fix this problem”
    I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the "Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver,” click (OK), this will ensure that the application take effect.
Now for the Internet.
The best thing to do is to restore the Internet Connection settings back to “default” settings.
To Start, go to the “Control Panel,” you want to open the “Internet Options” window.
Check the [Home Page], if your default "Search Engine" was changed, you can type it in example: (“Google”), click “Apply,” after each change.
Note: If you are not sure of the [Home Page] name, click on the “Default” block.
Next, you want to change the "Security Settings," to make this a safe and easy process; the rule of (“Thumb”) cannot go wrong with “Default” settings, click on each Security Zone, and click the “Reset all zones to default level.”
To setup the Internet Connection: Click on the “Connections” block, click the “Setup” button, follow all the instruction carefully. Important! “Always click Apply, OK, and restart the computer after making changes to the computer. “If this solution help? "Let me know by giving a "Helpful Rating, thanks."
May 29, 2010 | Toshiba Satellite A75-S229 Notebook
I cant get through yahoo messenger im my pc, cant download it and i am now using ym through meebo, but i always get dis connected
Your system administrator blocked all connections concerning yahoo.
Ask a system Admin to open it up for you or just be contented with using meebo before they could found a way of blocking meebo too.
Feb 05, 2010 | Computers & Internet
I cant connect to internet on my ds
you need to find a wifi enabled game, Pokemon Diamond for instance and at the starting menu select the most suitable sounding option, usually wifi options or Connection settings, from there it is easy.
have fun. :D
Sep 13, 2009 | Nintendo DS Lite Console
Norton software won't allow me to reach the internet
Are you logged in as an administrative user on the machine? If so, when you open up NIS2009, you should see three groups of controls. The middle group for Internet should have the a link for Settings next to it. Click on that. Enable the option for Automatic Program Control (might be on an Advanced Settings tab). This will let the firewall configure itself when a new program is run instead of asking the user. It normally gets the settings right. In the Program Control tab, select the programs that it is blocking that you want to allow and change the Access setting from Block to Allow or Auto.
Apr 14, 2009 | Symantec Norton Internet Security 2009
Ipod click wheel color screen
If u don't have itunes installed then the ipod should have disc use enabled automatically when you plug it in to the computer. Are you running windows xp? Perhaps connecting usb devices is blocked by admin aswell?
Jan 09, 2007 | Apple iPod 4th Generation MP3 Player
Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
