Question about InFocus ScreenPlay 4805 Multimedia Projector
Picture The picture has a yellow streak down the right side. I changed the lamp but it is still there.
    Brigadier General:
  • 6,966 Answers
Hi, Might it be the lens? The exposed portion of the lens do get covered with grime and dirt, maybe not much but when used, it gets baked because of the heat from the lamp. Cleaning it by wiping is not enough. You have to use a solvent to really clean it. One thing to remember is to clean it when it is at room temp and not after use (even a short one). The sudden change in temp is not that healthy for the lens. Since you were able to change the lamp, perhaps you can also do the inside portion of the lens. Treat it like your eyeglasses or the windshield of your car. Sometimes you really have to rub on it hard to remove the stains and smears. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 16, 2007
  • Louie  Role
    Louie Role Sep 16, 2007
    Hi again,
    I was really tempted to suggest vinegar as the solvent, but you are probably better off to get solvents/cleaning solution and wiping cloth specifically for projectors in ebay.
Mt 32 inch Bush lcd has a yellow streak running vertically through the picture. Is it worth getting it repaired ?
A yellow streak down the middle of an LCD Direct view TV (Not projection) is almost 100% the LCD panel. NO, just buy a new set.
Mar 30, 2010 | Televison & Video
I need a fuse box diagram for my 95 dodge dakota
Fuse 1: 30A, Green; A/C Heater Motor Fuse 2: 30A Silver (Circuit Breaker); Power Windows Fuse 3: 15A Light Blue; Overhead Consule, Day/Night Mirror, Reverse Lamps Fuse 4: 5A Tan; ABS (There is not on in the picture) Fuse 5: 20A Yellow; Power Door Locks Fuse 6: 20A Yellow; Horn Relay, Instrument Cluster, Radio Choke Relay (on Premium audio system) Fuse 7: 10A Red; Buzzer Module, Stop Lamps Fuse 8: 20A Yellow; Headlamp Switch Fuse 9: 15A Light Blue; Cigar Lighter Fuse 10: 20A Yellow; Windshield Wiper Fuse 11: 20A Yellow; Turn Signal Fuse 12: 10A Red; Radio Fuse 13: 4A Pink; Recives power from Fuse 8 to power instrument lights (such as the cigar ligher lighting, ash tray light, dash lights, radio lights, etc.) Fuse 14: 15A Light Blue; Instrument Cluster Fuse 15: EMPTY Fuse 16: 5A Tan; Buzzer Module, 4WD Indicator Lamp, Tranny O/D Switch, Tranny Oil Temperature Sensor Fuse 17: EMPTY Fuse 18: EMPTY Fuse 19: EMPTY Fuse 20: 25A Natural; Park Lamp Relay, Off Road Lamp Switch (There is not one in the picture, I believe this is only on vehicles with fog lamps)
NOTE 1: Fuse 3 and Fuse 14 provide power for the Airbag Control Module Cavities 2, and 1, respectivly. NOTE 2: Fuse 4, Fuse 7 and Fuse 11 provide power for the Controller ABS Brake Cavities 7 and 12, 9, and 3, respectivly.
Under Fuse 4, 8, and 12 is the Buzzer Module (Black rectangle in the picture) Under Fuse 16 is the Hazard Flasher (Silver circle in the picture) Under Fuse 20 is the Horn Relay (White plastic looking in the picture) To the side of Fuse 17 and 18 is the ABS Warning Lamp Relay (Open cavity in the picture) To the side of Fuse 19 and 20 is the Turn Signal Flasher (Blue circle in the picture) Between the Turn Signal Flasher and the Horn Relay is the Time Delay Relaly (the other Silver Circle in the corner, in the picture
Dec 16, 2009 | 1995 Dodge Dakota
We purchase a Hitachi TV #42V515 Sept 2005. We
Go to the place you bought it from and ask them, to me it sounds like your color wheel is going.
Nov 20, 2009 | Hitachi Televison & Video
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
Blue screen
I would suggest getting another optical block from the repair man. Apparently even some replacement blocks have had issues...
Jun 06, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
May 27, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Hitachi UltraVision has blue streak on right side of screen.
convergent systems.. I callled Hitachi....
it cost $600 to relpace the part... all 3 colors red yellow blue,.... tech took the part out and will replace it in about 3 or 4 days.
I was told by technician that it was a very very good tV in fact he said he would buy it from me for $300 and take it away.. I am considering that ... but a new one with Picture in picuture will be 2000 or more
Apr 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Picture problem
Was any parts changed lately? Like the engine wheel or etc?
Dec 07, 2007 | Hitachi 42V715 Rear Projection Television
the light tube has collapsed..there is a repair for this
Sep 15, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
