Question about Cell Phones
USB NOT WORKING SAMSUNG SGH-810 MOBILE PHONE
I HAVE SOMEHOW DISCONNECTED MY USB FUNCTION. I CAN STILL CHARGE MY PHONE BUT CANNOT ACCESS INFO LIKE PHOTOS OR DOWNLOAD STUFF OFF THE PHONE NOW.
  • 1 more comment
  • pp99 Apr 16, 2009
    I am so sorry to dissapoint you but, when I connect my usb cable it use to pop up with 4 options and those included download data and charging and you could choose what you wanted to do. Now it just goes straight to charging and does not give the other options. I know exactly how to get info off my phone. AND I dont have to switch my phone off when I connect the usb cable as I said I normally get asked what function I want to perform. I have a connectivity section on the phone which has the blue tooth, usb and Connection manager etc. And NO your advise did not work.
  • pp99 Apr 16, 2009
    I have switched off my phone and then plugged in the usb cable and then only switched it on but, nothing happens. What now?
  • pp99 Apr 16, 2009
    How do you do that please
    President:
  • 2,004 Answers
Laughs. This is because you don't seem to understand how to go about it.
Procedure:-
Switch off the handset before connecting to the system and there it goes....it will open as a flash drive wherein all its contents will be in sorted folders and you can copy and delete as if you are working on your computer folder files.
Cheers.
Rate this fixya
Posted on Apr 16, 2009
  • 1 more comment
  • Onifade Adewunmi
    Onifade Adewunmi Apr 16, 2009
    Please try the way I told you. It worked for me before.
  • Onifade Adewunmi
    If it worked on your system previously, then uninstall softwares and blnetooth and install again.
  • Onifade Adewunmi
    Yes I do.
The phone would not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 08, 2012 | Samsung Blackjack SGH-I607 Smartphone
What is the security code for samsung SGH-D900
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 15, 2010 | Samsung SGH-D900 Cellular Phone
I can't figure out how to access the email function on the t239. The TMobile clerk told me she loaded my hotmail address into the phone, but since the User's Manual doesn't mention email, I can't figure...
According to the Samsung, the cell phone does not directly support e-mail functions, but you can access e-mail such as hotmail using the web2go feature. The following is taken directly from Samsung's FAQ section of your SGH-T239 phone.
Does My SGH-T239 Phone Support Email?
No, the SGH-T239 handset does not have any configurable POP3 or IMAP4 applications available. However, via T-Mobile 's web2go there is available a T-Mobile Mobile Web feature. This feature provides, with certain E-Mail services, the opportunity to receive "new mail" alerts with shortcut access to your Inbox to read, delete, and respond to your e-mail as if you were on your PC.
For further assistance with the use of this T-Mobile service we recommend contact your provider.
Feb 01, 2010 | Samsung SGH-t239 Cell Phone
Connecting my sgh D900i samsung to the computer
is there a function in there for you to enable usb catridge or does it have a card slot?
some phones you have to enable the card slot or internal memory. if not the phone will just charge.
Aug 15, 2009 | Samsung SGH-D900 Cellular Phone
Can I charge my Samsung SGH-P310 through my laptop
Hi!
Yes you can charge your phone through your laptop if you have the Samsung SGH-P310 USB charger. You can purchase the charger through your nearest mobile phone shop or through these sites:
http://in.samsungmobile.com/accessory/PCB200
http://www.everymobilephone.co.uk/samsung-sgh-p310.htm
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Dec 31, 2008 | Samsung SGH-P310 Cellular Phone
SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
Dec 11, 2008 | O2 Samsung SGH-E250 Cellular Phone
Software for instale data cable for samsung c506 cel
http://uk.samsungmobile.com/supports/softwaremanuals/softwareManuals.do
Dec 03, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-E250 cell phone
I have a samsung SGH-E250 mobile phone i am unable to change the phone lock code, i hav tried numerous combinations including 0000 and none works. So am asking 4 help does any one know the code or knows how to reset or sumthing oh the phone was made in china
Nov 11, 2007 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
106 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
