Dell Motherboard
Problem for Dell (E210882) Motherboard
E210888, no power, light on near the place marked
By AAHHRR on Sep 15, 2007
Happened when trying to turn on, switch not respond. Found light near the place marked F
Comments:
Sep 23, 2007
- I tested, Power Pupply is OK. Why the light is on the motherboard even without switch on? Fan on power suppy was not on either.
Same Problem
Feb 16, 2008
-   Similar problem but no lights at all. No response to anything.
Tracypenn62@clearwire.net-   Troll61
Jan 27, 2008
-   Working on a computer for a co worker found the same results.Won't power up but light on Mother board. At first I thought it was the power supply but shorting pins 14 and 15 the fan started running. Pulled the mother board to check for burns or any indication of short none found. Now I'm stumped?-   babell2
Dec 23, 2007
-   Motherboard does not POST but there is a Light on the motherboard indicating power. A new power supply was installed, but no life yet.
Reset Bios, and Chassis Intrusion not the answer. Slight burn in smell, (not new board) but no heat. Possible overheating due to heat from dust.
-   Canick
Best Solution
posted on Mar 09, 2008
Very Helpful)
babell2
Rank: Apprentice
Rating: 100%, 2 votes
My fix turned out to be a replacment Mother Board, $95.00 Ebay buy it now. Computer is up and running and gone.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
0smon
Rank: Apprentice
Rating: 100%, 1 votes
i had the same problem, and was a little shortcut with the board and the case, try to check if your board is touching a some little aluminium parts of
the board, sorry but my english its not too good.
Cuida los tornillos del board que no esten tocando nada, la parte si la parte de abajo del board toca algo de aluminio por seguridad el no te prendera ,trata de montar el board en algo de forma tal que no toke el case
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 19, 2007
Very Helpful)
meanbob
Rank: Apprentice
Rating: 78%, 2 votes
Power supply fried
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
how can plug power buton,power led,rest buton in intel board e210882
Answer
my optiplex gx240 suddenly wont hold bios settings. changed the board battery...no joy. confused!
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
