Question about Palm Treo 750 Smartphone
I hv palm treo 750 and it stock on logo
Maybe sum1 cn hlp my prblm coz i try soft & hard reset but nothing's happen...
  • renylpocs Apr 16, 2009
    tnx 4 d advice but i dnt dat der is aplm center in our country..
    i/'ve try to search i all forum but it does'nt hlp... may this phone need to upgrade its firmware... maybe sum1 cn share a software on hw to upgrade palm phone .. tia..
    President:
  • Palm Master
  • 2,923 Answers
Are you saying the the phone won't turn on or off?
Try to remove the battery out of it and leave it removed for about 10 to 20 seconds. Then put the battery back to the phone.
If you will get the same problem, bring your phone to the authorized
Palm Center. This may need to have a firmware upgrade.
Posted on Apr 16, 2009
  • Melvin Ramos
    Melvin Ramos Apr 16, 2009
    Kindly check this link for software download:
    http://mytreo.net/downloads/treo-750-upd...
Palm treo 750 only shows the Palm screen on startup and nothing more
check soft ware at first , then hard ware solution by cleaning the board , be sure that keyboard is clean enough.....
Apr 20, 2011 | Palm Treo 750 Smartphone
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
Freezes up on palm logo
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to do it, and it's reset.
Feb 20, 2010 | Palm Treo 750 Smartphone
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
How do i reset my palm treo 750
Soft reset = push button behind the SD card door with stylus.
Hard Reset (WILL ERASE ALL DATA) = push same button after holding down the red phone button.
Oct 09, 2009 | Palm Treo 750 Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
Resetting data
May 07, 2008 | Palm Treo 750 Smartphone
Touch screen not responding
There is a treo repair website that shows you how to replace the screen yourself.
May 04, 2008 | Palm Treo 750 Smartphone
Hard reset
There is another reset that is designed to stop the Treo from looping. System(warm) Reset. Make sure you have the battery charged fully or plugged in before doing this one. It is available on the Palm.com site. Select your model and look for troubleshooting or type System (warm) reset into the search bar. It also concludes with a soft reset. Here is the short version: press and hold the UP button on front panel and also press and hold the sylus in the reset button. Hold both of these until the second Palm logo appears. Then release the UP button. Then, the reset button. Now do the soft reset(batter out then in).
Apr 02, 2008 | Palm Treo 755p Smartphone
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Palm Treo 750 Smartphone Logo
81 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
