Afternoon, I have a major problem with my Dimplex DAC15HC portable air-conditioner. It either requires constant top-ups to its external water tank, or the main evaporative water tank leaks constantly, irrespective of both tanks being emptied on a daily basis. At this rate, I'll be re-carpeting the room the unit is in!! Any help would be gratefully received. Cheers, Simon
  • SAJF2 Apr 16, 2009
    Hi Tartan, many thanks for your comments and advice. To be more specific, on two occassions recently, I have woken (say, 7 hours sleep & moderately humid night) to find +/- 3 square meters of carpet and underfelt well and truly soaked through. Ihave owned this unit for two years, and it has performed perfectly until now - is it worth a service call? Lastly, how does one check the lower drainage pipe for leaks without removing the cover? Again, many thanks for your help. SAJF2
  • SAJF2 Apr 17, 2009
    Tartan, many thanks for your excellent advice. Much appreciated. SAJF2
  • 10,515 Answers
Hi SAJJF2,
Its not leaking. As the fan blows air across the cold coils the water in the air condenses on to the coil. When enough water condenses it forms drops which drip out of the AC unit. In humid parts of the world AC units can drip enough to be nuisance. In really dry parts of the world you may not get any condensation at all.
If you really think, that it's not a problem of condensation, it's leaking....Check the pipe that goes to ground. There must be a leak in it.
Thanks for using Fixya.
Posted on Apr 16, 2009
  • taran_2005
    taran_2005 Apr 17, 2009
    Hi SAJJF2,
     If the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
    Just concentrate on the water, Is that comming from the pipe or A/C unit and you would know the culprit...
    Do rate the solution.
My Dimplex DAC15HC has stopped working it turns on as usual just no air flow, what do I do?
Make sure the filter is clean and if it is it sounds like the fan motor stopped working.
Mar 21, 2011 | Heating & Cooling
I have a portable air conditioner from dimplex, dac15hc, it cools when 1st turned on then aprox 1-2 min later i hear the compressor turn off, the air coming out gets warmer until a code of ES is shown on...
E5 Outdoor activation of compressor over heatprotection or motor lock. Check fan motor mechanism is locked. Replace fan motor.If compressor getting high amps, replace running capacitor and check. If still problem, replace compressor. Thanks, helpful.
Feb 01, 2011 | Heating & Cooling
How much water should be put into a Dimplex Portable Air Conditioner DAC15HH? The user manual does not say how much. There is a clear strip on the side which runs the full height of the unit which allows...
On your unit do not put water into it. Only when the water level reaches the line do you empty it. The collection of water comes from the air conditioner condensing the water and collecting it in the tray. Hope this helps you. ken
Jan 06, 2009 | Heating & Cooling
Water leak with the dimplex dac12ac
Hi there seems to be a water outlet at thtop rear of the unit where you need to drain water from its a little" rubber plug" hope this helps good luck
Dec 07, 2008 | Heating & Cooling
Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Jan 23, 2008 | Heating & Cooling
Water spillage in Dimplex portable air conditioner
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Jan 01, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
