Question about Sony DSR-45 Mini DV VCR
Error code c2100
Where is located moisuring sensor ?
  • alekhan Apr 17, 2009
    Sensor locate on the left'n'bottom part of board under mechanical deck. like a comb
    Problem Solver:
  • 17 Answers
Here's link to a picture of typical moisture sensor. clean it with a q-tip and alcohol. (http://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/88013-moisture-condensation-2.html)
Posted on Jul 02, 2010
    Problem Solver:
  • 17 Answers
Your vcr is having condensation symptom.you can try 1,let it on for 2 hour, 2, you can open the upper body then you can use hairdryer the mekanik near where you push the cass, the sensor near the left reel.
Posted on Jul 08, 2009
Code C2100 2008 chrysler sebring what that means my car giving that code
C2100 Engine Fault Code Check Solution For C2100 OBD Code : C2100 engine code seems a kind of chassis problem, we try to show one by one the meaning and the solution.
Brief explanation of the C2100 code and definition of C2100 is the bottom side.
C2100 Meaning :
c Chassis Code
Problem is controller area network wiring bus and modules. 2 MFG - Manufacturer Specific 1 BBV Sensor Circuit Low Voltage 0 Low Coolant Circuit 0 Park/Neutral Postion (PNP) Switch Circuit Engine Torque Signal Circuit MFG - Manufacturer Specific codes, which have a '1' as their second digit to indicate they are unique to a particular vehicle make or model. These special codes were deemed necessary by the vehicle manufacturers so they could provide additional diagnostic information beyond the basic list of generic OBD II codes for all kinds of faults, not just emissions-related faults.
How To Fix C2100 ?
There are currently two main types of cylinder deactivation used today, depending on the type of engine. C2100 code for the pushrod design which uses solenoids to alter the oil pressure delivered to the lifters. In their collapsed state, the lifters are unable to elevate their companion pushrods under the valve rocker arms, resulting in valves that cannot be actuated and remain closed. C2100 Code Description: The oxygen (02) sensors on your car measure the oxygen in the exhaust to determine how rich or lean the ratio of fuel and air are in the cylinders. Optimizing this mixture means better fuel economy and fewer exhaust emissions. When you see C2100 engine fault code on your engine code reader this description will help you.
C Codes List of all Chassis codes. Final Step: In the definitions listed below, there is a test drive recommended after you've completed any repairs to see if the condition is fixed. Before you take a test drive after a repair, always erase the C Code(s) first. This will turn the check engine light off and then you will know if the check engine light returns, you've got further diagnostics to complete.
Nov 29, 2016 | 2008 Chrysler Sebring
I just got my car scanned and a few codes pop up
Error Code: P0130
Fault:
Oxygen Sensor (O2S) 1, Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
-Wiring harness.
-Oxygen sensor (O2S).
-Engine control module (ECM).
Error Code: P0505
Fault:
Idle Speed Control (ISC) System - Malfunction
Possible Cause:
-Wiring harness.
-Idle speed control (ISC) actuator/Idle air control valve (IAC) valve.
-Throttle motor.
-Throttle valve tight/sticking.
Error Code: P0100
Fault Location:
-Mass Air Flow (MAF) Sensor/Volume Air Flow (VAF) Sensor - Circuit --Malfunction
Possible Cause:
-Wiring harness.
-Mass air flow (MAF) sensor.
-Volume air flow (VAF) sensor.
Error Code: P1491
Fault:
Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
Possible Cause:
-Wiring harness.
-EGR Valve.
-ECM
Error Code:P1607
Fault:
-Engine Control Module (ECM)/Powertrain Control Module (PCM)
Error Code: P0966
-Pressure Control (PC) Solenoid B - Circuit Low
Possible Cause:
-Wiring short to earth.
-Pressure control (PC) solenoid.
-Engine control module (ECM)/Powertrain control module -(PCM)/Transmission control module (TCM) .
Apr 30, 2013 | 2004 Honda Civic
I went to scan my toyota yaris car and the following codes were give ; temperature ckt low input po117
EOBD II Error Code: P0117
Fault Location:
Engine Coolant Temperature (ECT) Sensor (G62) - Low Input
Possible Cause:
Coolant thermostat.
Engine coolant temperature (ECT) sensor.
EOBD II Error Code: P0340
Fault Location:
Camshaft Position (CMP) Sensor A (G40), Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
Wiring from/to Camshaft Position Sensor (CMP) faulty.
Camshaft position (CMP) sensor faulty.
Timing misaligned.
Possible Solutions:
Check Wiring from/to Camshaft Position Sensor.
Check Camshaft Position Sensor.
Check Timing.
EOBD II Error Code: P0500
Fault Location:
Vehicle Speed Sensor (VSS) - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Non Emission Fault - No warning light.
Wiring.
Vehicle speed sensor (VSS).
Dec 13, 2012 | 2001 Toyota Yaris
Canon C2100 I have an error code E677. Can you tell me what the problem is.
This error on your printer is a fault in communication or communication error between the computer and the laser printer. You have to clean every socket or plug of the Printer and you have to also get attention on the internal hardware configuration.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Canon C2100 Laser Printer
Need user manual and/or service manual for Canon imageCLASS C2100
here you go...this printer model is known as cp660 on other regions (based on their Web site).
http://printer1.blogspot.com/2008/03/canon-cp660-service-manual.html
hope this helps.
Mar 05, 2009 | Canon imageCLASS C2100 Laser Printer
DSR 45 VTR
possible defective dew sensor, but don't overlook capacitors in the sensor circuit.
Oct 15, 2008 | Sony DSR-45 Mini DV VCR
Canon C2100 copier going into a E021 error code and display says drum yellow
Make sure you have the developers correctly installed ... E021 means you have a rotary error.....
Jun 27, 2008 | Office Equipment & Supplies
Service Call e021
I believe that is a dirty sensor error message.
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Feb 23, 2008 | Canon imageCLASS C2100 Laser Printer
Sony DSR-45 Mini DV VCR Logo
832 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
