Question about ATSI Holdings BD422003 Thermal Label Printer
Balster advantage label printer form feed
Helloi have a Blaster Advantage BD 422003 label printer driven by XP Pro. when a label prints it is followed by a blank label. a vaste of expensive labels. i cannot see where a form feed is being sent to the printer. how do i not gat a blank label?
thanks David Cree
  • mybl Apr 16, 2009
    THANKS FOR THE SUGGESTION, HOWEVER THAT IS NOT THE ISSUE. IF ONE LABEL IS SENT TO THE PRINTER THEN IT PRINTS FOLLOWED BY A BLANK LABEL.
    President:
  • 2,923 Answers
Hello David,
You have to make sure that the printer is not running out of ink.
Try to uninstall/re-install the printer driver. This often resolves the issue about printing problem.
Posted on Apr 16, 2009
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
How do I copy a format file from a Cognitive AdvantageLX printer to a file. I need to transfer the format file from one printer to another because I don't have the original format file on hand.
Use this command from the CPL programming manual. Sorry I have never tried it so I do not have more detail. I'm looking to find a way to get the source of a label format since I need to modify one. Any input would be appreciated.
Get Object Data
Function This command is used to get the binary data of an
object.
Explicit Form !OBJECT UPLOAD location id
location
Memory location to store the defined
variable. The following memory
areas are available:
0 – Volatile Ram
3 – Nonvolatile Ram (Flash)
Parameters
id Stored object identifier assigned
when the object was first stored.
Comments This command can be used to get an object out of
one printer, and then download the object and use it
in another printer.
This command does not require a header line, but
must be followed by a line feed (or carriage return
and line feed). Do not use any other commands with
!OBJECT UPLOAD.
Example This will send the binary data for the Ultrafont B in
Volatile Ram to the current communication port
Jul 26, 2010 | ATSI Holdings Cognitive Blaster Advantage...
Our Blaster Advantage prints too low on label
Printer needs to be calibrated. This can be accomplished through the driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 12, 2009 | ATSI Holdings Cognitive Blaster Advantage...
There is a label stuck under the roller. This is causing the labels to jam when printing.
Platen roller needs to be taken out to remove label. Recommend, sending unit in for service.
Nov 15, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Blaster advantage printer does not print in proper spaces on labels
Try calibrating the printer. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Jul 29, 2009 | ATSI Holdings Cognitive Blaster Advantage...
We are facing the same problem
Jun 11, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Align advantage blaster printer
Download the Printer Setup Utility at cognitive.com.
Apr 14, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Cognitive Blaster Advantage PROBLEM
Printer needs to be calibrated. This can be accomplished through the printer driver or setup utility.
Apr 10, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Printing off to one side after reloading drivers
Make sure the roll of labels are pushed all the way over to the left in the label bucket.
Mar 23, 2009 | ATSI Holdings COGNITIVE Thermal Label...
ATSI Holdings BD422003 Thermal Label Printer Logo
253 people viewed this question
Top ATSI Holdings Office Equipment & Supplies Experts
jasbo
jasbo
Are you an ATSI Holdings Office Equipment and Supply Expert? Answer questions, earn points and help others
