Question about Apple iMac G4 20" Mac Desktop
My DVD-drive needs replacing. Is this possible on a Mac?
Hello! I have an iMac and the DVD/CD drive is playing up. It invariably doesn't recognise an inserted disc, particularly blank/homemade discs, and throws them out after having had a noisy think-about -it. Is it possible to put in a replacement drive on an Apple as you would with a PC? Thanks for your time! Phill from London
  • Martin Buck
    Martin Buck May 11, 2010
    Yes it is possible to replace the drive. The procedure is different depending on which iMac you have. If you can tell me which one you have, I'll let you know the procedure.
    President:
  • Apple Master
  • 1,619 Answers
Yes, Just check your apple drive to see what it is set to primary or slave and replace as same. www.xlr8yourmac.com has great resources to check drive compatibility.
Posted on Jul 09, 2009
  • 558 Answers
Yes you can however for me to help you i need to know more information.
Graysand
Posted on Sep 14, 2009
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
My G4 1.25ghz with 1 gb ram plays abc video slow.
Hello, sorry you are having trouble,
There are so many variables when it comes to Video play back on a Mac..
Yea, 1.25 Ghz with 1 GB of Ram answers most questions, yea, it should play OK,
BUT:
  • Is the video on a CD or DVD ? well, these iMacs don't have a very fast optical drive.
  • How much room do you have on your internal hard Drive, if it's too full ( more than 80% full ) then you will suffer read/write performance.
  • Is the video on an external harddrive, is it a USB drive? the USB on the iMac G4 is USB 1.1, 11Mbit/sec, way too slow to play a big video smoothly.
  • Just what is the size of the video, is it like that for all of them or just one, might it be a HD video with high frame rates?
  • What version of the MacOS X do you have installed? If you installed Leopard 10.5 on the iMac G4, nothing will run smoothly,
  • Are you playing this video over a network? forget it it's got to be on the internal or a FireWire external disk otherwise it will stagger...
Well, there you go, I know, it's so easy to say Hey man, just get a new Mac and everything will be fine... But that machine is going on 6 years old now, Video technology has not stood still.....
Mar 24, 2009 | Apple iMac G4 Desktop
CD/DVD Drive Doesn't work
Hi, Sorry to hear you are having problems,
One final test to try before declaring the drive dead:
Insert a bootable installation CD or DVD and restart right away. If the system ejects the disk, simply re-insert it as soon as possible after you hear the start up sound and then, immediately press the ( C ) button on your keyboard forcing the Mac to boot from the cd....
If your Mac boots, then the drive is OK it's your system that has a problem.
If the disk is ejected again, then you can declare the drive dead. It is a relatively inexpensive repair and if your Mac is still under warranty, then apple will take care of this no charge.
Good luck
Mar 21, 2009 | Apple iMac G5 Desktop
Optical drive failure
try to clean the lens maybe you dont use it frome some time and there need a lens cleaning if no just change it with new one
Dec 14, 2008 | Apple 2.16GHz iMac Intel Core 2 Duo...
My internal optical drive spits out dvd's and cd's.
When rebooting press and hold the Alt key until it displays all bootable drives. Now insert your disk. If it works install Leopard from here. If not then your drive is dead or faulty and needs checking or replacing.
All the best
Sean
PiDigital
Playing PS2 on apple iMac
if the iMac is one of the computers with the slot-load drive (you don't load the disc into a tray before it goes into the computer), then placing a disc smaller than a regular CD/DVD will damage the CD drive and will be very hard to remove.
you could buy an external CD/DVD drive and then use smaller discs with the iMac.
Jun 10, 2008 | Apple iMac G5 Desktop
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all Apple iMac G4 20" Mac Desktop Questions
Apple iMac G4 20" Mac Desktop Logo
207 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
