Question about Emjoi AP98R Epilator
Are there any replacement heads out there?
For some unknown reason (after 40 minutes of frantic poking with the tiny brush) the dual tweezer head has failed to continue spinning, though the wheel works perfectly fine.
Would an AP99 head work?
Are there any extra tiny brushes?
    Problem Solver:
  • 12 Answers
If you go to http://www.jr.com/emjoi/pe/EMJ_AY5S/
they have your razor and it's a rechargable one for only 34.99 plus 6.99 shipping but you might want to check out that sight
Posted on Apr 16, 2009
The rotating brushes on my floor setting keep stopping on carpet - even though nothing is clogging it. I have to turn my vacuum off and then back on to get it to start spinning again.
There are two things that cause this.
1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
Keith from Dyson Repairs North Shore Auckland
Sep 24, 2014 | Dyson DC29 Animal Vacuum
Why won't the brush turn on my Dyson DC40 Animal?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/search?type=product&q=dc40
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 19, 2014 | Dyson Vacuums
Jam instructions
Just pull out the cassette and use tweezers to remove any debris. Also, use the brush included to clean the print head (I suggest soaking the brush with alcohol first).
^CM
Jan 26, 2014 | Office Equipment & Supplies
How to clean a remington EP6010 epilator?
AFTER EACH USE
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual: http://uk.remington-europe.com/pdf/ep6010_user_manual.pdf
Feb 28, 2011 | Remington Health & Beauty
8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
THE BRUSH ON MY HEAD FOR THE SEBO K1 HAS STOPPED SPINNING WHY???
Check the brush roller at each side to see if threads are wound around it. Also, check the brush to see if there are threads wound around it. This is what generally stops the brushes from spinning. It will take sometime to unwind the threads/lint and you may need scissors and tweezers to fully remove all of them but it will be worth it!
Nov 01, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
Fossil Explorer watch BQ9381. It has 3 batteries. 2 are held with small screws and can easily be replaced. But the other one, how do you remove it?
This watch is relatively simple to work on, though you have a total of nine (9) screws, three (3) batteries of two different types, a spring-pin in the wristband, and an o-ring seal to contend with. Nonetheless, you should be able to do this in half an hour with the following tools: Fine tweezers, preferably curved tip; these tweezers should be able to draw blood if you poke yourself lightly with them. Miniature (jewlery) screwdriver set, with tips no wider than the thickness of a dime. Clean toothbrush. Mouse pad for a work surface (optional but highly recommended). READ ALL OF THESE INSTRUCTIONS BEFORE DOING ANYTHING. If you feel you are not up to the task, take it to a jeweler or reputable watch retailer (NOT WALMART!!!)1. Disconnect the 12 o'clock half of the wristband from the clasp. Remove the pin, and re-install it into the clasp so you don't lose it, or simply set it aside if you're afraid of it launching.2. Remove the four Philips-head screws from the caseback. Lift off the caseback and check the o-ring seal. If it starts to come off, remove it and set it aside.
3. There are three batteries in this watch: two (2) 392 silver oxides (they may also say 41, 192, or 384) run the analog movement and are held in place by two (2) Philips-head screws each, and one (1) 364 (it probably says 621) silver oxide running the digital circuit. It is best to replace all three at once to get the maximum life out of each battery per change to minimize damage to the seal by unnecessarily opening the watch several times.
4. Using a pair of tweezers, carefully remove the self-adhesive insulators that cover the two larger 392 batteries; set them aside adhesive side up where they won't get in the way. Then remove the two Philips-head screws from each battery clip. After removing the first one, the second will likely get "stuck" in the clip as the contact pushes it upward at an angle, engaging it with the threads. Don't worry about that, but do be careful not to lose either the screw or the clip. Repeat for the second 392 battery.
5. Remove the one slotted-head screw from the 364 battery clip. You may need tweezers to remove the screw, clip, and battery from the battery recess. DO NOT TRY TO DROP OR SHAKE THESE OUT.
6. At this time, you may want to clean the perimeter of the watch opening where the o-ring seal will be replaced. Use a toothbrush and try to scrub away any dirt. Don't brush across the open PCB of the watch as you will get dirt inside it that way. Gently work your way around the outside.
7. Installation is reverse of removal. Remember, there is ONE of the smaller 364 batteries down in the recess, and there are TWO of the larger batteries on top.
8. When you have ensured that all five battery screws have been properly replaced, and the self adhesive plastic insulators have been positioned properly and are sticking to the clips on the 392 batteries clips, hold the o-ring seal between your fingers only tight enough that you can pull it through your fingertips with little effort. Wipe the entire o-ring seal in this manner for several rotations.
9. Gently stretch the o-ring around the perimeter of the opening. Use tweezers to position it, then hold it down on one edge and work the tweezers between the inside of the o-ring seal and the outside perimeter of the opening so that it guides it into place. It may try to "roll" out of position; keep running the tweezers around the perimeter until the "roll" works itself out and the o-ring seal stays seated nicely in position on its own.
10. Replace the caseback, ensuring that the orientation is correct: the top of the text will be in the 12 o'clock position, which is where the band that was disconnected from the clasp is. The crown knob will be facing left with the watch face-down while the text is legible.
11. Re-connect the band to the clasp. Insert the pin into the end of the band, then insert one end of the pin into the clasp. Angle the other end in and if your band hasn't twisted around too much, you may need to use your tweezers to compress the pin into place. Rotate the pin and band until both ends find their hole.
12. I did mine in about 15 minutes, and no additional work was needed to "restart" the watch although the time needed to be set, obviously. Your results may vary. The digital portion was not dead when I replaced its battery. I am not responsible for lost or damaged watch components. I'm just a guy on the internet.
Sep 06, 2010 | Watches
Records on right channel only so only get music from right speake
If you are recording from an outside source check the connections are good. If it does it from both IE dubbing and external it is possibly that a wire has detached from the head of the record head. The other likely source is the record amp inside the deck. Trace the leads from the Tape head (recording one) and see if you can locate a switch, these can get dirt on the contacts and cut out channels (clean with Servisol video 40). It could also be the electronics especially the amp chip!
If not then the head itself may have gone.
Mar 19, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Terrible grating sound when trying to print!
It could be timing issue with print head or the feed mechanism. You will have to get a service manual if you want to fix it yourself.
This link here was the only site I could find that had information on getting a service manual
Jul 31, 2008 | Epson CX4200 Stylus Color All-In-One...
Emjoi AP98R Epilator Logo
134 people viewed this question
Top Emjoi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Emjoi Health and Beauty Expert? Answer questions, earn points and help others
