Question about LG Washing Machines
LG WD-1219BD Front Loader that hates me
Hi All,
I'm having no end of problems with my LG WD-1219BD front loader. The machine fills and washes ok, but when it comes to draining it pumps a little water out then the machine error codes and beeps like crazy.
I have removed the pump and checked the impellers which had a little piece of plastic from one of my kids pockets. No blockages in drains at all.
Replaced everything and the machine worked without a problem for 3 loads and the problems back. Removed pump again but nothing in it this time. Just wondering what else it could be electric motor on pump or a sensor or something.
Please help as the washing is mounting up and I cant afford to have it fixed.
Thanks in advance
Julie
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
  • 99 Answers
SOURCE: LG Tromm Model # WM2075CW doesn't drain - water everywhere!
This is joyce
I hope you have not been waiting long for this answer, go to the website lg.com dowload your document on your washer put in your model # first and then it will give you all the info you need on that machine even trouble shoot it and codes. I hope this helps.
thanks,
joyce
Posted on Feb 07, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
taran_2005
  • 10515 Answers
SOURCE: 5 year old LG WD-1219BD has error code LE, ''overload in motor''
LE is a very bad error unfortunately. It means that your motor communication is being lost. Generally on these LG washers it means that you need to replace the motor sensor. You will have to take the back panel off so that you can access the motor, remove the pulley and take the motor off, there is a little plastic sensor that clips onto the edge of the motor. The sensor is not sold separately from the motor so you will have to replace the motor unfortunately.
Part would cost you around $120 plus labor.
This is a common error on LG. Better to repair and use it or fix it yourself.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 11, 2009
Testimonial: "Thank you Guru. Your advice was spot on what I needed to know and has assisted me greatly. Thanks again!"
Wiring diagram for kg80490np washing machine front loader
More details required. i.e kg? np? Brand name enter minimum details in Search box should show up and suggest.
Good Luck
Feb 03, 2015 | LG Washing Machines
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
My LGfront end loader washing machine is shaking so bad it actually walks across the laundry room 3 -4 feet
I had the same problem when my LG WD-8074FHB was new. LG recalled them and put a larger weight in them. The weight is a hollow piece of plastic filled with concrete in the top of the machine under the cover. It stopped it moving around the laundry.
Mar 04, 2014 | LG WM1814CW Front Load Washer
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
LG WFT653A, water continuosly filling
that solinoid must be conected rong
sean it before
Jan 22, 2009 | LG WD-14124RD Front Load Washer / Dryer
Washing Machines Logo
213 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
