Question about Uniden Cordless Phone
GE 25861GE3B want to add more rings before answering machine comes on want to add more than 10 names to speed dial mickey Michell miknal@sbcglobal,net
  • 150 Answers
Good day Mickey, First I'll provide you with a link to the manual if you need it: I know it's a weird lokking link, it's a server from thompson which is the parent company for GE home electronics, not exactly yoo east to find. Anyway on to the problem at hand, To make it answer after more rings there is switch on the back of the base. It hase 3 settings 3/5/TS. If set to 3 it will pick up in rings, set it to 5 and it will pick up in 5 rings. The TS setting stands for TollSaver, do not use this setting, TS will cause it to pick up in 2 rings. Set it to 5, however if you want to get 10rings before it picks up there's a little trick. When the answering machine gets full it will start picking up in 10rings, they do this so you know your answering machine is full. You can still leave a meassge even when it's full, it will automatically delete the oldest message to make room for a new one. However the display on the machin will display an F instead of the number of new messages. Well I hope the helps with that problem, because I hate to be the bearer of bad news but that phone has a maximum capability of 10 speed dials (0-9) and that's the max. There are models on the market with lots of speed dials but there usually corded phones. Well Good Luck & I hope this helps. L8R
Posted on Sep 17, 2007
How do I delete and add numbers to the speed dial on my Samsung SF340 fax machine
1 Press and hold the Speed button for about two seconds.
• The display shows Speed [00-80]>##.
2 Enter a two-digit (00~80) number and press Enter.
• From 00 to 09 will be used for One-Touch dialing, and from 10 to 80 for Speed dialing.
3 Enter the telephone/fax number you want to store (up to 40 digits) and press Enter.
• If you want a pause between numbers, press Redial/Pause; a 'P' appears in the display.
• If you make a mistake while entering a number, use to move the cursor under the digit, then enter the correct digit.
4 Enter the name and press Enter.
• If you do not want a name, just skip this step by pressing Enter. If you have subscribed to a Caller ID service,
it is recommended you enter a name.
• You can assign up to 20 characters to a name. see "How to enter letters" on page 1.7.
5 Press Stop/Clear to exit.
Feb 12, 2011 | Office Equipment & Supplies
How do you change the number of rings before machine turns on?
When the AT&T 1717 digital answering machine is powered off it will answer an incoming call after 10 rings, it will announce "machine is off" then beep twice, dial 0 to turn it on. The machine is now ready to answer calls. This 10 ring setting is factory set and cannot be modified. To set the number of rings to answer for normal operation press <SET UP> button and hold for 2 seconds, machine will announce current ring setting. Press and release <ANNC/SKIP> or <MEMO/REPEAT> until you hear the number of rings you want. Press and release <PLAY/STOP> to exit. The ring settings available are 2, 4, and toll saver. When set to toll saver machine will answer after 4 rings when there are no new messages and after two rings when is anew message. Here is a link where you can download manual,
Dec 09, 2010 | AT&T 1717 Digital Answering Machine
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do you set up the rings for a lexmark fax machine lexmark 6570
Setting Auto Answer to on
From the desktop, double-click the Productivity Studio icon.
2 From the Welcome Screen, click Fax History and Settings.
3 From the “I Want To” menu, click Adjust speed dial list and other fax settings.
4 Click the Ringing and Answering tab.
5 From the Auto Answer drop-down list, select On.
6 Click OK to save the setting.
The Auto Answer light on the control panel comes on. When the number of rings you set is detected, the printer
automatically receives the incoming fax.
Hope this fully answers your question. Best of luck.
Jun 26, 2009 | Office Equipment & Supplies
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
Oct 05, 2017 | GE 21008GE2 Dual-Handset Cordless...
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
No dial tone
no dial tone on my cordless
May 01, 2008 | GE 25932 Cordless Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Uniden Cordless Phone Logo
237 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
