Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
To reset The printer
Hello ,My machine is brother MFC-240C When i was printing a page , the paper got stuck in the machine . the machine said to remove the paper by removing the back cover . When i removed the paper from the machine still it was showing the same message on the LCD screen . This message was not going away , even if i cancelled all the prints from my computer . Then i plugged off my printer because it was not even switching off by pressing the off button . Now when i plug the printer and the usb to the computer , the printer starts , and within one second it restarts . The problem of restarting is continous . The machine automatically switches off and again restarts . I want to know that why is this happening ? And how the problem can be resolved . I think this problem can be resolved by myself but i dont know how to do it . as this problem happend some days earlier and one of my Friend resolved the problem . but my friend is not here at the moment , so it is urgent and i am waiting for your reply .... Thanks
    Problem Solver:
  • 12 Answers
HI...the desing of brother printer that remove the back cover thing it is kinda confius to user...the back cover is to REMOVE paper THAT STUCK and you need to close it back..and it wont remove the error message coz it dont have sensor on the cover you need to lift up your scanner then close it it will continue.... The problem you have accour is you MainBoard need to be reinstall or replace coz it has be shock by the usb that your pc sending Data on it then you have cancel it...Try get to engineer this problem cant be solve by user....Thank
Posted on Apr 25, 2009
Mfc-240c prints lines in black
It may be your printer head that needs to be flashed. if you have not use the printer in a wile, the ink drys out and clog up the nozels. Do printer head cleaning, if not work, use paper towel with a little warm water, press the printer head on it.
Jan 03, 2014 | Brother MFC 240C All-In-One InkJet Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
How do i reset a brother mfc 240c
To reset the MFC-240C, hold down the power button for 3 or 4 seconds. The lights on the display should go out and the printer should slowly turn itself off. Once it is off, hit the power button again to restart it.
If the power button does not work (as sometimes happens with paper jams or other error conditions) you can unplug the machine's power cord in order to reset it.
Oct 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Regular paper jams and printed images are not straight
hi,
follow these steps:-
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
mannu_rakesh
Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
My brother printer240C had a paper jam .
hello Just a checklist: have you tried to reboot the printer? Are you totally sure that no paper is stuck? have you tried to reboot the computer also? Hope this helps
Jun 10, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
312 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
