Question about Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009
I wont to put wheels under a chest freezer to move it
I wont to put wheels under a freezer to move it aroned
I moved my freezer on its side to clean and it wont get cold any more what do i do/
Fridges and freezers often don't like being started right after they have been moved/tipped, it's best to give them some time (a few hours) in the upright position to allow the refrigerant fluids to settle back where they're supposed to be before restarting.
Jun 29, 2011 | Danby 5.5 cu. ft. / 156 liter Chest...
Chest freezer model mfco5mobw4 been plugg in for 2 days now set on the coldest setting not getting cold compressor is warm
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Apr 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
My chest freezer does not freeze over 80% of the case.it only freezes a small seccion of the upper part of the case.
This one sounds just like a refrigeration problem.
If the freon leaked out then it will definitely do this...
I would recommend to get a new freezer here's why.
if you call someone to put the freon back in it will cost you anywhere from $80 to $150. it will freeze and work good but eventually it will go back to the same problem because the tech did not fix it only put it back in... its just a matter of time then you have the same problem... save your money and move it to a new one...
hope this was helpful
Mar 06, 2010 | Whirlpool 14.8 cu. ft. Chest Freezer...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
My brand new Danby compact chest freezer is very noisy.What is the problem?
It could be an area where the tubing is vibrating against the cabinet or it's touching other tubing. While it's running you can run your hand along the tubing and when you get to the vibrating area it should stop. You can then slightly move the tubing away from where it's vibrating. Do not bend or kink the tubing.
It could also be a noisy compressor which would be under warranty.
Aug 26, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Moving, CA to Florida and want ot load a chest freezer on its end
You could expect internal compressor oil to flow into areas which would restrict refrigerant flow, resulting in no cooling. If you have to ship on end, make sure the compressor end is down !
Jun 07, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Chest freezer not getting cold after moving
IS the compressor running? If so u probably cracked a line and lost the refrigerant charge.
Feb 27, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009 Logo
1,185 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
