Question about Sony Playstation 3 (PS3) Console
What is broken my hdmi cable,ps3 unit or the hdtv?
When i turn my tv on, my ps3 starts to load then red and green dots or pixels appear then disappears
when i play any games after a couple of minutes the bottom half of my tv flashes white for a second if its not the bottom half its the upper half that flashes
when i quit the game and the ps3 goes to home those red and green
dots or pixels appear again
could you tell me whats broken or how to fix it??
  • 1 more comment
  • ps4 Apr 16, 2009
    the rca cable doesnt work do you know how to fix it??
  • ps4 Apr 16, 2009
    its fixed in the rca cable no dots but its still the same when i use the hdmi cable it still has the dots
    should i replace the hdmi cable??
  • ps4 Apr 16, 2009
    is there a chance that the hdmi out connector in my ps3 is broken??
  • 21 Answers
I would suggest this (you haven't said what kind of tv you have). I have a 37 in vizio, and a 25 vizio flatscreen HD tv. I had my PS3 hooked up using HDMI first time I tried it I got the little pixels you were talking about...so do this. Sounds stupid but it helped me. The HDMI cable where it plugs into the tv plug and unplug a couple times (three times worked for me. Do the same at the PS3 side of the cable. You want to do this with both of the machines off. Also make sure you have the PS3 configured appropriately for your TV settings...There is a way you can auto setup the screen and sound by shutting the PS3 off and holding your finger on the power button for like 5-10 seconds (it will beep twice) then let your finger off the power button.
When my HDMI cable went bad it would go from having a picture and sound to having no sound and a picture, to no sound and no picture. I thought I had a bad HDMI slot...but it was just a bad HDMI cable
Posted on Jun 07, 2009
    Scholar:
  • 44 Answers
I would do some testing to figure out what is causing the problem.
First try hooking something else up to the TV, such as a DVD player or other gaming console. If you get the dots again then it's the TV that is having problems.
Second, if the TV passes the test then try connecting the PS3 to the TV using the RCA (red, white, and yellow) cable that would have come packaged with it. That will let you know if the HDMI cable is the culprit.
Third, if the first two did not help then it's looking like the PS3 is the one having problems.
Hope this helps :)
Posted on Apr 16, 2009
  • Brendan Rose
    Brendan Rose Apr 16, 2009
    Sorry about that, I totally forgot about that problem.
    You'll have to hook both the RCA and the HDMI connections to the TV to start. Using the HDMI connection you need to go into the PS3s settings and change the video settings to output to RCA instead of HDMI.
    I gave a more in depth explanation in another solution:
    http://www.fixya.com/support/t1358919-wa...
  • Brendan Rose
    Well from the looks of it HDMI is where the problem is, and yes, it could either be the cable or the HDMI port. Hopefully it's just the cable.
    From here I would suggest picking up a new HDMI cable and testing it out, if you still have problems then it's the HDMI port and you're better off returning the HDMI cable. If your PS3 is still under warranty you could get it repaired, otherwise you may be stuck with using the RCA connection.
    Good luck :)
I keep getting green dots all over tv screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 15, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
PS3 keeps freezing with colorful pixels. How can I fix this?
You need to use a vacuum and suck the back out or blow it out with air . While power is off on PS3 turn power on holding down the eject button it will blow it self out .
Sep 20, 2014 | Sony Playstation 3 (PS3) Console
I changed the PS3 setting to view on TV from HDMI to Ycp? (red blue green cables) now I can't see the PS3 menues, how do I change it back? can you help please My PS3 has no Red blue and green out
try taking out the red blue green cables completly out so no cables should be conected exept for the power cable then plug in the hdmi cable from the ps3 to the tv after you do that turn on the tv to hdmi input then turn on the ps3 and let it sit for a while and look at the tv while the ps3 is turned on shortly after you turned the ps3 on a message should pop up on the tv select yes then set the settings and that should work let me know if it dosent
Dec 08, 2012 | Sony PlayStation 3 (320 GB) Console
Random HDMI audio and video drop out & video noise
Hello, I am sorry about your issue. I suggest that your receiver be looked at by a service center. Thank you. Onkyo USA
Apr 03, 2017 | Onkyo TX-SR606 Receiver
Hd tv as no hdmi plug
There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
Cheers
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
Green dot's and pixelation via hdmi
its the ps3 u have to send it back to sony! the green dots will get worse and start to freeze up ur system i had the same problem last month!
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,382 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
