Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
Electric Fireplace replacement remote
The manuel for my corner hearth electric fireplace doesn't say anything on how to replace the remotes. I believe it came as a set about 4 years ago from Home Depot. The oak cabinet says it is made by CFM (which I believe is out of business). The insert is a charmglow. I can push the buttons and control flame and lighting, but neither of the 2 remotes that came with it work. I would like to find replacements. If so, is there anything I need to do to program them with my particular unit? Thanks
4 Suggested Answers
  • 10865 Answers
SOURCE: appearance
hello. i can help. here is the home depot number to call. insist that they take it back, they will, if they say no tell them you will report them to the better business bureau and the attorney general for your state.
Charm glo is their brand. they are responsible to make your purchase good. keep good notes about your call. always ask the persons name and then ask to speak to their supervisor. be nice but firm. do not lose your temper. you will win this one.
Posted on Jun 24, 2009
  • 139 Answers
SOURCE: Push button igniter appeared to be missing parts
did you put a new battery in, if won't work turn the battery around the other way and see if it works if not call back charmglow and ask them to send a new one to you.
Posted on Oct 18, 2009
richroth
  • 9472 Answers
SOURCE: Purchased a electric fireplace from
What is the make of the fireplace?
Posted on Jan 26, 2011
Febo Electric Fireplace Insert Using remote It Will Not Auto Shutoff when room reaches temp. also If room is Cold & Temp is set higer it will not turn on. U have to manually shut it if or on. there is...
Maybe its the fireplace's ignition spark box at the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Oct 24, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
The heat on my Pyromaster HEF33 Electric Fireplace is not working
This unit was made by Monessen Hearth Systems. The original heater/fan part has been discontinued; however, there is a new part that is compatible with your fireplace. You will need to search for part#10006404 Fan/Heater.
Nov 30, 2012 | Leisure HOMEPRIDE Electric Fireplace...
Smart stat 2 fireplace remote chirps similar to a smoke alarm. batteries have been replaced twice. Chirps at the receiver which is a plug in style no batteries. The beep can be stopped for a few hours by...
The chirping has nothing to do with your fireplace or electrical. The Smart Stat II remote is for use on a millivolt system only. The receiver sends out a signal every 15 minutes. If it can't find the hand held remote, it will chirp. The hand held must be within a 15 foot range. There were some issues with the remotes back in 2009, I believe. They were faulty and would chirp for no reason. They were covered under warranty for one year. In my opinion, these remotes are not as good as they should be. A TV remote lasts for years without missing a beat and has a better response rate. I've seen these replaced up to three times a year. At $229 a pop, hmmmmmm. You be the judge. Sorry for the side track. Move the hand held closer to the fireplace. The decorative front that is on the fireplace can also interfere with the signal as the receiver is under the fireplace and the metal front can stop the signal. Either pull the receiver out from underneath and set on the hearth or just pull it closer to the front to keep hidden. Another issue with low voltage systems is dirty connections. If your wall switch or remote just suddenly stops working, try unplugging all connections and reconnect. Being low voltage, any bit of corrosion will prevent it from completing the circuit. Gas fireplaces are not difficult to work on or maintain. Just use common sense. There is a 110v outlet underneath to power the fan and any kind of electronic ignition there may be. So be sure to lock out the breaker if needed and shut off the gas supply. Most electronic ignition systems have a battery backup that will start the fireplace and radiate heat. Batteries should only be installed when the power is lost or they will corrode and be useless. The respective brand website usually have owners manuals and replacement parts breakouts for your review or download. Hope this helps. Crank up that fireplace and stay warm!
Sep 01, 2011 | Skytech Smart Stat Fireplace Remote for...
My electric fireplace don't work,I replaced the electric swith but still wont work,gas comes,I noticed that it does not make the noise while turning on that it use to make before.
I took the fireplace's direct connect ignition spark box out of the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Nov 23, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Dec 13, 2009 | Kitchen Appliances - Others
Electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Oct 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My Heater stopped working on my HEF33 Electric fireplace. My fireplace is only 3 years old not sure what to do.
We have had this same problem with our heater. But I went online to find out where I could purchase replacement parts. The company that sold the fireplace went out of business. I also went on-line to try and fine a universal replacement part. So far no help to be found.
Nov 18, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Problem with HomePride model TE555 fireplace heater
I hav ethe same heater but my coil does not get hot. I am trying to find a replacement part for it but no luck. I called the number (905-847-2643) of the company but no call back.
Jul 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Jamil nj
Hi Jamil
To help you out a little bit the Company you need to go through is a Vermont Casting or a Majestic Dealership... Alot of companies will only help you if you have purchased from them.
If you have a problem? Is there anything I can help you with?
Nov 19, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
279 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
