Question about Garden
When I mow the mower just comtinualy reves up and down like its straving for fuel the lawn mower is a victor sabre silver colour 4 stroke
SO WAS MINE, AFTER STRIPPING IT DOWN THREE TIMES I FINALLY FIXED IT, JUST ASK FOR A CARBY GASKET SET TO SUIT YOUR MODEL REPLACE IT EVEN IF IT LOOKS OK LIKE MINE DID, AND AWAY SHE GOES!!
REGARDS
KEV.
Posted on Mar 11, 2012
    Problem Solver:
  • 14 Answers
Try checking the air filter or you might have to adjust the govenor spring.
Posted on Jun 19, 2009
Engine runs rough under load
how old is the motor
4 stroke with valves or a two stroke ?
blades
spark plug , coil , air fuel mix check valves
re check governor setting
if grass is way above the front height of the frame it will struggle
raise the height first to max on the first run
then lower
or use a grass trimmer to knock the level down before mowing
May 17, 2016 | Garden
How to use
I guess from the photo it is petrol (gas) powered.
If it is electric, it needs to be plugged in or if battery charged.
Fuel - depends if 2 stroke (oil + gas) or 4 stroke (just gas)
If gas - "prime the engine" - there is likely to be a little brass button you press to get a few drops of fuel into the engine. Then - pull the starter cors or press the starter button if battery starter. Make sure there is a bit of fuel on the throttle before starting, but not flat out!
One you've got power, mow safely!
Sep 19, 2015 | Garden
Mower wont start
chech to see if plug bad make sure you are getting spark if it is spray some starting fluid in it see if it starts if it does checkfor water in gas if no rebuild carb should run
Jul 03, 2014 | Garden
How do you set up a carbaretta on a flymo petrol qs46sd
2 stroke or 4 stroke engine? Check out the link from "tillitson" 2 stroke carb theory. GOOD LUCK http://www.tillotson.ie/docs/techinfo_HS_US.pdf
Apr 15, 2014 | Garden
Lawnboy help
ck. governor linkage connections
Jun 18, 2013 | Garden
Victor vantage 148cc 4-stroke mower revving too hard
pull off the top cover and look a for some thing blocking the governor linkage
Apr 07, 2012 | Garden
I have a Lawn Boy silver series self propelled mower, model number 10324-8902967 that leaks fuel from the exhaust under the mower deck after I have finished mowing and turned the engine off. I will drain...
sounds like the needle valve is not seating some have a rubber tip on needle some have it in the seat but the fuel we now have rot the rubber never store with fuel if possible
Apr 02, 2012 | Toro Lawn Boy Self Propelled CARB Walk...
I have MTD Yard machine and don't know if it is 2 or 4 cycle. Oil should be-SAE30. Can I use oil for 4-cycle which they soid me i Can. Tire.(M otomaster)
If your mower has seperate fill caps for the oil and the gasoline, then you have a 4 cycle or 4 stroke engine. In this case use SAE HD30 motor oil. If there is only 1 fill cap and it says oil & fuel mix, then you have a 2 cycle or 2 stroke engine.
Good luck
Sep 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Stalling
I have same mower and just fixed what seems like a similar problem description. I had gone down the fuel system route and the symptoms just didn't add up. Stopped abruptly w/o sputtering once I reached warm-up temp. Replaced the solid state ignition (34443C now part number 3444D). Problem corrected and just mowed my 1/3rd acre w/ no issues.
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
161 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
