Question about Roper REX4634KQ Electric Dryer
Dryer wont run
My dryer only runs on the cool down cycle it wont start up on any other cycle
  • Anonymous Nov 20, 2007
    I have a kennmore dryer and it want start. I test 2 fuse and i brought a fuse thrml
    Problem Solver:
  • 9 Answers
I imagine this has got an electronic timer ? If so then it's probably the timer board that's faulty.
Posted on Sep 16, 2007
If its a newer dryer, they have moisture sensors that determine if it should shut down early or stay on longer if needed. Let it run the extra time and see what happens. If it keeps doing it, then the sensor is defective.
Feb 21, 2016 | LG Dryers
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Dryer runs when first started, quits halway through drying cycle.
High temp. limit is probably at fault and will need to be changed.
Jul 13, 2009 | Whirlpool Dryers
Dryer wont run for long
After unplugging the dryer, disassemble and clear motor of all lint build up. Motor will overheat and cycle on the thermal protector if this is the case. Secondly, a malfunctioning centrifugal switch, shorted motor windings, or tight bearings could all cause this failure. A restricted vent could cause this in some dryer designs.
Jan 12, 2009 | Kenmore Dryers
Dryer wont run
defectvie timer,,,onthejob
Dec 07, 2008 | Whirlpool LER7646E Dryer
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
Roper REX4634KQ Electric Dryer Logo
146 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
