Question about Toshiba Satellite Pro L300 Notebook
No audio output device
How is fix
  • Micah Gregorio
    Micah Gregorio May 11, 2010
    Need a more specific model number for the computer. There should be more characters on the bottom of the computer. For example, L300-EX5223.
My computer is not detected any output audio device.
TRY THIS.GO TO SERVICES AND RESTART WINDOWS AUDIO.
Mar 02, 2014 | Computers & Internet
No audio output device detected
Missing sound driver is most common issue. You didn't say what operating system so it is difficult to provide detailed instructions for checking for the presence of the correct driver.
Sep 11, 2013 | Dell Latitude E5500 Laptop
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
"no audio output device is
I understand that audio output device is very important to a laptop. But don't worry there's a website where you can download the device for free.
Please just click_here so that you will be directed to the exact site.
Thanks.
Aug 22, 2011 | Compaq Presario 700 470024-192 Notebook
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
Hello, my playstation 3 digital output is no longer emitting a light. I tried the cable with another playstation 3 (slim version)and the audio works fine. I turned the not working ps3 off and unplugged it...
make sure your audio output settings are correct,
Settings > Sound settings> [Audio Output Settings] > Select the input connector on the audio device. (Channel numbers and audio formats that are supported vary depending on the connector in use.)
  • HDMI
  • Digital Out
  • Audio input connector/ scart/ av multi
Jan 17, 2011 | Video Game Consoles & Games
Hello i have an ACER Extensa 5420 that said no audio output device...How can i fix it??
http://global-download.acer.com/GDFiles/Driver/Audio/Audio%20Realtek%20.6.0.1.5404_Vistax86.zip?acerid=633643020790033772&Step1=Notebook&Step2=Extensa&Step3=Extensa 5420&OS=V10&LC=en&BC=Acer&SC=PA_6
copy and paste the above, its the latest sound driver, this will correct your no output device..
Dec 28, 2009 | Acer Extensa 5420-5687 Notebook
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
Toshiba Satellite Pro L300 Notebook Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
