Hello there. We have been trying to fix an intermittent audio problem on a Toshiba 29JZ5DM CRT TV but to no avail. We actually tried replacing the AN5277 audio output, check & established earth connections, fixed cold solder joints but still, the problem goes, then comes back the next day. Also, the problem comes whether the unit is cold or have been switched on for hours. Any help is highly appreciated. Thank you so much. -Ben F.(Manila)
    Brigadier General:
  • 5,158 Answers
Check all the capacitors you can find on the boards.... not just visually but with your fingers.... any that feel swelled up and or rounded on the top have failed. i realize this isn't the same as an lcd monitor but i had the same symptoms with it that you are experiencing and that was the fix... before you start touching the capacitors make sure the power has been off for at least a half hour... and still be careful.
Robert
Posted on Apr 16, 2009
Need codes for toshiba t.v model no.29JZ5DM
You would be better with an original remote, if you program a universal it will if works at all be missing key and needed features.
Dec 20, 2012 | Televison & Video
Toshiba SD-P4000 TV no picture and intermittent audio. Had been fine. Bought Sept. /2004. Perhaps TV life is over? JK
HI,
You are correct but it can be fixed actually. The picture problem in your Y Sus and the audio problem is on your audio circuit. You need to decide to repair it or invest for new one.
Regards, Jay
Feb 23, 2011 | Toshiba SD-P4000 14 in. TV/DVD Combo
Hello! The picture on my toshiba cz36v51 is halved vertically, and has a duplicate picture on either side. Is that fixable? This problem occurs when trying to watch movies, cable, xbox...etc. Fixable or...
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Aug 28, 2010 | Toshiba CZ36V51 36" TV
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
Are audio boards still avaiable for toshiba 30hf84
I have a Panasonic with a defective audio output, and found a cheap alternative to an impossible to repair problem.
Mine still had audio if I connected headphones to it, but the speakers would get nothing. I found that a decent set of computer speakers (with sub woofer) worked great, and I could move the speakers to provide awesome stereo. Sub woofer is behind the TV.
I did a quick look and did not see an audio specific board available. Likely, it's part of the main board and not cheap to replace.
I hope you can use my fix. It's actually a better sound now than original.
Jan 16, 2010 | Toshiba 30HF84 30" TV
Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Apr 11, 2009 | Toshiba 36AF42 36" TV
Toshiba CRT
Hi Keith,
Your Hi-Fi is designed to produce many watts of audio power. It would be a fair assumption that you took out the output section of the audio amplifier of the CRT.
The best way to accomplish sharing the speakers between the CRT and Hi-Fi would have been to use a switch box, that way both audio sources would be isolated from each other and whatever source was not being used would be put into a dummy load.
You need to find the Part number of the damaged part. If you open the CRT (power unplugged) you will probably be able to find it with your nose, since it was damaged and burned up.
Call MCM Electronics with the part number and see if they can cross reference a replacement for you.
http://www.mcmelectronics.com/
1-800-543-4330
Good Luck,
- Jim
Jan 24, 2008 | Toshiba 32A33 32" TV
Have intermittent sound on one channel
sounds like cold solder connection on main board./audio section
Nov 19, 2007 | Toshiba 32AF43 32" TV
Audio, but No video when connecting DVD player to TV
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Apr 15, 2007 | Toshiba CZ27T31 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
