New dell laptop dosn't boot from battary ,power cable shoud be pluged
My dell laptop dosn't boot without power adapter i have to connect it to the power to boot successfully , my battary and laptop are new
  • 1 more comment
  • ehumaid May 07, 2009
    Thank you driveallnigh my problem  is fixed by just removing the battary and reinsert it.
  • Kevin
    Kevin May 11, 2010
    Remove the battery and check to see if there is a protective sticker over the contacts. If so, remove the sticker or object and reinsert battery. Remember the battery has to be charged before you can use it.
  • Dick
    Dick May 11, 2010
    A new battery isn't charged, have you read the directions?
    Scholar:
  • 148 Answers
  • two ways to charge the battery:
    • while the laptop is on
    • while using the laptop with a power cord, but it will take charging time when you are using the computer.
  • --if the problem persist, the battery may have a problem, called dell technical support and have the battery serial number for possible battery recall. or replacement
Posted on May 02, 2009
Inspiron 5547 will not turn on
Ok first of all is the laptop getting any power?Does anything light up? are any of the caps,scroll or numlock lit up ?flashing?
if not then remove battery and only connect the power adapter. Power laptop on. Anything? Jiggle power adapter cable to see if thier is a break in the cable.Jiggle the connection from where the power adapter connect to the laptop. Could be the DC jack /power cable
Go to this link for further instructions
How to Resolve No Power No POST No Boot or No Video Issues with Your...
Aug 02, 2014 | Dell Computers & Internet
I can wrok without battary in laptop , any problems can occure
Most laptops can work without a battery but the power adapter needs to be connected to the laptop.
Mar 07, 2013 | Computers & Internet
New adapter computer will not come on and the battary will not carger the computer
You can test adapter output with any multimetr, if its working then try to boot laptop without battery, if not power on, then you can check power socet and fuse near power socet on motherboard. To reset CMOS on most laptops you need to remove CMOS battery from motherboard for about 15 minutes. Also, if it is not solve your problem you may add more detailed information about laptop model and details about this problems with pictures. Thanx
Nov 15, 2012 | Dell Computers & Internet
Dear Experts , I have a power problem with my DELL PP01L laptop ,it was very well operating and suddenly it goes off ,i tried to repower it on again but in vain ,Could it be a battery problem ? but i...
It should work even without the battery when the power adapter is connected. Try to check if there is a green light on the adapter itself. Also check the cable of the adapter and the contact point at the end of the cable that goes to your laptop as well as the port on your laptop. Check if they are broken. To test, borrow the same model of adapter that works.
Oct 12, 2010 | Dell Latitude C640 Notebook
My dell d610 sometime powers up in to xp then just freeze them sometime just 3 geen lights flash then nothing can you help
If there is a power issue, the first thing we need to determine is if it's the power adapter or the battery. Is there any difference if:
- You boot up with the battery in but the AC adapter not connected?
- You boot up with both the battery and AC adapter connected?
- You boot up with the AC adapter connected but the battery removed?
If different things happen for each of these scenarios, the problem is either a faulty power adapter or battery, depending on which one you can boot up without.
May 12, 2010 | Dell Latitude D610 Notebook PC
IBM Thinkpad R32 No power, no led with ac adapter plugged in. With or without battery. Tried new ac adapter and no change...
may be you have lose welding in the inside connector
it is possible to charge your battary in another laptop and try your laptop...
Feb 19, 2010 | IBM ThinkPad R32 2658 Notebook
Powere adaptor has to be unplugged to boot
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 22, 2009 | Dell Precision M90 Notebook
My Dell precision M90 will not turn on all the way it acts like its going to boot up and then comes to a screen that either says the battery can not support the system press F1 to shutdown (when it is not...
Seems that either the battery or the power adapter is defective. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 27, 2009 | Dell Precision M90 Notebook
Connecting laptop to tv
1. If your tv has a PC input, use a vga cable, from any normal computer monitor.
2. If you use those HD connectors, match them to the correct colour coded inputs on the tv.
In each case, do all the connecting with the computer POWERED OFF. Then when connected, boot the computer, and allow Windows to auto-detect the 'new monitor', as it will 'see' it.
Then you shoud right click on your desktop, choose properties, and goto 'settings'. From there you will see monitors 1 and 2. click on the new monitor and 'enable' it.
You also have the option of 'extending' windows to the second monitor, as well as making this your 'default monitor'. Experiment to see what best suits your needs,
Erik.
May 16, 2008 | Dell Precision M60 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
