Alpine CDA-9813 CD Player Logo
Posted on Sep 15, 2007
Alpine CDA-9813 soundless
I have gone through the wireing 3 times now, and cant seem to find anything wrong with that, but there is still no sound comeing from the cars main speakers, just the subwoofers. Any ideas would be helpfull really dont wanna take it in to have it reinstalled.
  • chevyll Jan 01, 2008
    I am not getting any sound. I have gone thru my programming, wiring and all is set right and still no sound. Every thing lights up with no error messages. Is there a reset for the internal amp? I noticed my cooling fan on the head unit is not on.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 02, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
544
Points
On your cd player hold down the f button for few sec. It will take you to the setup screen. You will then scroll till you see POW-IC make sure it says ON if it is OFF then only your subs will play and no door speakers.
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Sep 17, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
6389
Points
18
What car do you have? see if it already has an amp for main speakers
My cda-9813 wont power on,how to take of faceplate?
sure it will the face eject button should be either on the upper or lower left corner of the face.
4answers
Alpine cda-9813 no power
You check the radio fuse in the fuse panel?The wire connections are right? Check the Owners Manual for other details or troubleshooting: ALPINE CDA-9813
Hope helps.
I have an alpine cda-9813 and it quit playing cd's. it still plays the radio is there anything I can do? or anywhere I can send it to?
if it has totally stopped playing cds just throw in the towel , unless you somehow have a warranty which u probably o not b/c that is an older model .if it plays sometimes get a lens cleaner it may help . there are local stereo stores that can fix it but its probably not worth the money . My advice go on ebay or craigslist and get a new one . good luck
4helpful
CDA-9813 No sound, will not eject CD
There is a very tiny dot located either on the actual face of the alpine head unit or on the front plate of the radio once the face has been removed. Once you find this dot(if on the actual face) you need to make sure unit has power turned on and witha tiny needle or pick you may push this reset buton in for about 2 seconds. The face will automaticaly fold down and the disk will eject itself. Once this is done do not place the same disk back into the unit. Hope this solves your problem
ALPINE CDA 9813
make sure that the acc and ground are hooked up right. acc has to be 12v. if you hooked it up to any other wire it will work until you(turn it up) draw more power than the wire you have it connected to can produce. or you have speakers that are faulty or too big for the alpine head unit.
2answers
No sound
The stereos audio amplifier IC is damaged.
No Sound
everybody here got took by alpine. get together form a class action suit.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
