Question about Nokia N73 Cellular Phone
My mobile very slow system
Zx,
  • 1 more comment
  • kucherawalaa Apr 16, 2009
    my problem is bettry is not usage so wants to low
    Genius:
  • 1,011 Answers
Dear,
nokia n70 and n73 symbian based mobiles have slow operating system. But you have to check it for virus by download and installing antivirus in it...
http://www.filebuzz.com/findsoftware/Download_Free_Antivirus_For_Nokia_N73/1.html
regards,
hopefully, it will fix the issue so dont forget to rate it...
Posted on Apr 16, 2009
Having fuel issues with my 1999 zx9r, i have already cleaned entire fuel system, bike will crank if i put my hands over air intake on carb, any suggestions?
Hi, Michael # 9 and 10 are jumping up and down waving a red flag and yelling "PICK ME" otherwise the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
1999 Kawasaki ZX7R Ninja Won Start Need Your Help Fuel Economy Hypermiling...
My ZX9R wont start need help asap
Kawasaki Ninja ZX 9R Service Manual
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/showOM_nv.php?view_lang=EN&spec=EU&category=MC&book_no=99922-1933-03&lang_code=EN&code=&nickname=&modelyear=
Dec 07, 2016 | 2000 kawasaki ZX-9 R Ninja
2000 Kawasaki ZX-6R Ninja dies with throttle
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump or internal fuel line has pinholes.
17. Fuel injectors clogged or faulty.
18. Faulty throttle position sensor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Ninja starts but dies when open the throttle
http://www.newninja.com/forums/f161/zx-6r-starts-fine-but-dies-when-throttle-is-applied-16041.html
Kawasaki Ninja ZX 6R Service Manual
Kawasaki Ninja Owners Manuals
May 18, 2014 | 2000 kawasaki ZX-6R Ninja
2001 Kawasaki ZX-12R will not idle
Hi, Otacteofan and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://kawasakiworld.com/zx-12r/45849-01-zx-12r-rough-idle.html http://www.zxforums.com/forums/mechanical-technical/40220-2000-zx6r-wont-stay-running-stuck.html
Kawasaki Ninja ZX 12R Service Manual
2001 Kawasaki Ninja ZX 12R Owner Manual
Mar 06, 2013 | 2001 kawasaki ZX-12R
1997 Kawasaki ZX-9R Ninja will not idle without choke
99 ZX7R wont idle without choke ZX Forums
Bike will not run off choke KawiForums Kawasaki Motorcycle Forums
Jul 31, 2012 | 1997 kawasaki ZX-9R Ninja
2006 Kawasaki ZX-6R top speed
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
https://www.topspeed.com/motorcycles/motorcycle-reviews/kawasaki/2006-kawasaki-ninja-zx-6r-ar1875.html
http://www.zx-6r.net/forums/kawasaki-zx-6r-forum-general-discussion/27574-636-top-speed.html
Who has hit top speed on their bike and how often ZX6R Forum Kawasaki Ninja ZX 6R Service Manual
Jul 16, 2012 | 2006 kawasaki ZX-6R
HI THERE, I HAVE ZX-I945LM4 MOTHERBOARD, BUT I CANNOT INSTALL WINDOWS VIST, WINDOWS 7 OR WINDOWS 8 IN MY PC.. .WHAT WOULD BE THE SOLUTION FOR THAT.. . THANKS AND REGARDS.. .
hi your board support xp,,u need to update your bois to 2010 atleast to get vista and win7 to work and u need 2g ram..good luck and if u use copy cd rewrite the disk in slow speed 4x then it will work
Mar 28, 2012 | Computers & Internet
I have no audio driver of ZX I945LM4 Ver... 1.12 so, please send me driver download link or driver
Corrupt or missing sound drivers. Compatibility issues with the operating system or other hardware. Speaker related issues. Bad or missing sound card.
Sep 17, 2011 | Computers & Internet
2006 Kawasaki ZX-6R error code 43
Hi, D_J_bourke for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
http://www.zxforums.com/forums/zx-6r-forum/46047-fi-code-43-a.html
Kawasaki Fault Codes
Jun 19, 2010 | 2006 kawasaki ZX-6R
My zx-12 turns off after running for a while?
Sounds like your charging system is failing. You should have 12 volts on a battery when not running, and around 13.5 or so while running. Check it with a meter if you can.
Jul 16, 2009 | 2002 kawasaki ZX-12R
Nokia N73 Cellular Phone Logo
108 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
