Question about SanDisk Sansa e200 MP3 Player
Sansa e200 Doesn't Work
Every Time i recharge my battery my screen works and says Connected but I can't turn it on.
  • 626 Answers
The battery may have become loose from the contacts. So it turns on when connected, but the battery is not charging. Try removing the screws on the back, take out the battery and put it back in. Then charge the device for a couple hours and see if it works. Best of Luck.
Posted on Sep 15, 2007
Hello i'm venkat.. i have a problem in my sansa 8gb ipod ..its got shut down due to low battery and when i was recharging it, it's not getting on.... could u please tell me the address where it can be...
You could send in the Sansa E280 to here: http://www.pdasmart.com/pda-battery-center/battery_SANDISK_SanDisk-Sansa-e280_battery_center.htm
They will replace your battery for you.
You could also purchase the battery here: http://www.amazon.com/Sandisk-Sansa-Battery-E200-E250/dp/B003E4WL6K and install it yourself.
How do I replace the battery on the Sansa e200 player?
1. Remove the back on the e200 by removing the 4 screws.
2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove. NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player.
3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player.
4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place.
5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable.
6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device. NOTE: If the device goes directly to a black screen after unplugging it, then the battery has been replaced incorrectly. Take the back off the player once again and flip the battery around and the e200 device should work properly.
Mar 09, 2011 | SanDisk Sansa E280 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
My sansa e200 is frozen
this could mean the screen is burnt out not that it completely broken or that its not turning on.
Jun 22, 2009 | SanDisk Sansa e200 MP3 Player
Wont recharge or even start! Help!
http://go.shopsansa.com/content/batterykit.Replace the battery.Everything you need to do it is at this link.This is a fixya solution please vote blue.RICHARDM69
Dec 26, 2008 | SanDisk Sansa e200 MP3 Player
How to open a battery cap in sandisk sanca c240
How do I replace the battery on the Sansa e200 player? trnsp.gif trnsp.gif trnsp.gif trnsp.gif trnsp.gif Answer 1. Remove the back on the e200 by removing the 4 screws.
Dec 16, 2008 | SanDisk Sansa e250 MP3 Player
SANSA E200 NOT SHOWING THE MENU SCREEN
Try to format the SANSA E200.
You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE.
AND FORMAT THE PLAYER . if this dosen't work your player is faulty
Nov 21, 2008 | Computers & Internet
Sansa E200 Problems
try taking the battery out of it.
Mar 23, 2008 | SanDisk Sansa e200 MP3 Player
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
Battery Recharge
"Removable drive" sounds like it got set back to MTC mode (USB mode in sansa settings menu). Needs to be in MTP mode to really be of any use. I have the e280 and it recharges fine when it's hooked up to my PC. It might be the battery, the connection, or the player. Also, it has to be a "high power" USB port on your PC (whatever that is). ie: If you're on a really old PC, there might not be enough juice getting through to the player. But if the rechargers don't work either.....
Dec 01, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
