Question about Canon PC-D320 Copier
Canon pc-d320 copying problem
Hi!
When I make a copy of some documents with presses (marks from stamps) like ID, the copy doesnt contain any of those presses.  So copy is a literally blank teplate of document without stamps! I guess its kind of problem with copier's exposure options and I wanted to correct its manually but whe I disassembled the device I did not found any variable resistors to correct the exposure settings. The problem is that copier doesnt copy semitone and light colours what on the copy supposed to be gray.
Is there any ideas what can I check and do? Does somebody know where is that goddarn variable resistors for exposure in canon pc-d320?
please help.
p.s. I guess it's not a problem of cartridge, scanner of printer parts. Cause it printing actually quite good.
  • rain9 Apr 16, 2009
    Here is the URL to picture containg original and a photo.
    http://i21.photobucket.com/albums/b299/P...
  • rain9 Apr 20, 2009
    Dont u think I did that?!?! This is not a solution. Was it helpful? Hell no!
    Well somehow I came to idea that it is a problem of scanning mirror and how close it get to glass. Cause moving those mirror upper and lower of the glass makes the difference on copies. Although I did not make that really better and solve the problem.
    Sniper:
  • 67 Answers
You can take the machine off auto exposure and manually run the exposure darker using the exposure settting and + and- keys.
Posted on Apr 16, 2009
How do i print copys of MX310 printer manual
Do you mean the Canon Pixma MX310 all-in-one inkjet printer? If you wish to print a copy without using a computer, first make sure that you have ink and paper loaded and that the all-in-one is on and the paper output tray is extended. Place your document face down on the glass or face up in the automatic document feeder. (Note: the scanner doesn't see the document if it is within 2 mm of some of the edges of the platen glass. If you use the ADF, remove any document currently on the glass.) Press Copy (if the unit isn't already set to copy). Check the default settings on the LCD screen and enter the number of copies desired. Press Settings to change any items and use the left/right arrows to change the number of copies, if needed. Press the Color or Black button to make the copy(ies). Color for color documents and Black for black & white documents. Press Cancel to stop copying.
The FAQ on making a copy without storing the image on a computer is here: https://support.usa.canon.com/kb/index?page=content&id=ART120681&actp=search&viewlocale=en_US&searchid=1485643876501 .
The manual is available on the product support page: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx310 . Click on the Manuals tab. The manual is in a self-extracting executable file. You'll need to run the program and then find the icon or folder where the manual is stored. (The default location is C:\Program Files (x86)\Canon/IJ Manual .)
I hope this helps. If this doesn't work, please add a comment with any error messages that you see.
Jan 28, 2017 | PRINTER Office Equipment & Supplies
Canon PC-D320 problem
i think innk is smudging
Jun 11, 2008 | Canon PC-D320 Copier
Copies come out with what looks like a water mark down the entire page on the right hand side.
Hi; Simply, you must clean the unit of devthe eveloppent with a vacuum cleaner, and especially The Transfer roller, what you have is a cause of the toner from the magnetic roller.
Oct 13, 2010 | Canon imageCLASS D320 Digital Copier
Exposure problem
If internally generated prints are good, but copied documents are bad then your scanner needs cleaning. This can be found in the document feeder section where the light scans across the paper. If both copied and internally generated prints are bad, then chance are, your toner/drum catridge has run out.
Jun 18, 2010 | Canon D320 imageCLASS Digital Copier
I have a black solid streak on my Canon D320 copies
Change the OPC drum cleaning blade and clean used the vacuum cleaner the development station.
Dec 01, 2009 | Canon imageCLASS D320 Digital Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
How do I scan on my canon D320
While the D320 has a scanner, it is used only for making copies. You can connect the D320 to a computer and use it as a printer, but there is no provision for scanning documents to a computer.
Nov 07, 2008 | Canon imageCLASS D320 Digital Copier
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Canon PC-D320 Copier Logo
340 people viewed this question
old marine
old marine
