Question about Toshiba Satellite P35-S605 Notebook
What do you do regarding the toshiba satellite powering down
  • 1 more comment
  • lujan_sam Apr 16, 2009
    It turns on and then powers off. Whether it is ruuning on battery or directly plugged in.
  • Roberta Smith
    Roberta Smith May 11, 2010
    sounds like thermal shut down (it's getting too hot). you need to disassemble it to the point where you can access the fan area.... remove the covers for the fans as well and clean out any dust and dirt
  • Roberta Smith
    is it just shutting off on it's own ?
  • 326 Answers
Depending on a few things, this may be a feature or a problem.
Does it seem to shut down within a specific time period?
Does this time period remain constant, and change only if on battery vs. plugged in?
If this is the case then it probably your power management settings.
Check the control panel, and configure them to your preference.
To access the Power Options in the Control Panel in XP:
Start > Control Panel > Power Options
There you will see specific settings regarding monitor, hard disks and standby. Your machine is most likely going into standby, check the time, and select something more appropriate for your needs or disable it all together.
In Vista, you will see a more streamlined set of options. "Always On/Plugged In" "Minimal Power Saving" Etc. would be the best choice
The choice is yours.
Let us know.
Good luck
Posted on Apr 16, 2009
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
L500D has a broken power supply connector inside the laptop. Is this repairable? Regards, Matt
The 'power supply connector' is the DC Power Jack on the laptop.
DC IN
Repairable?
Yes Matt. Not really that difficult at all.
With most laptops the DC Power Jack is soldered directly to the motherboard.
Not so with the Toshiba Satellite L305 series of Notebook PC's.
The DC Power Jack has it's own cable, which is connected to the motherboard.
The DC Power Jack itself is a small rectangular shape. It slides down into a slot (Trough) made in the outside of the Bottom Case.
The cable leading from the DC Power Jack is composed of four wires, which are attached to a connector,
http://www.batterysupport.com/toshiba-satellite-l305-s5955-jack-p-329251.html
A) This is a pictorial guide to disassembling a Satellite L305 series of Notebook PC, down to the bare motherboard,
[ You don't have to remove the motherboard in order to access the DC Jack]
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L505-L505D/remove-laptop-motherboard-1.htm
B) This a link to a free Service Manual for the Toshiba Satellite L500 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading.
Begins with - Satellite A10.
Drop down to the second line, go to the right and click on - L500
This is a PDF file. It may take up to 30 seconds, (Sometimes more), for the first page to come up.
It may also take additional time for the file to fully download.
(Page navigation may not be at the top of the PDF file. Hover your mouse cursor towards the bottom of the page)
(Pages 127, and 128 deal directly with the DC Power Jack.
Disassembly procedures begin on Page 121.
Read the Anti-Static Precautions in - Before you begin on Page 129 FIRST )
Observe Anti-Static Precautions
1) Buy, and wear an ESD wrist strap. (Electro Static Discharge)
The average cost is around $3 to $5.
Connect the alligator clip to a good ground source.
{I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
Perhaps you have a large metallic object to use instead. (Unpainted) A large metal serving tray, or large metal knickknack}
2) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
{If a multi-compartment container is not available you can substitute with a clean egg carton. Label each egg holder }
Some screws are VERY similar to others. Do Not mix them up.
3) Make a record as you disassemble. Make notes, drawings, and/or photograph/video record.
Nice to have a record to refer back to in case you are interrupted, and have your own personal notes besides the manual, and guide.
Regards,
joecoolvette
Aug 13, 2011 | Toshiba Satellite L500 Series Notebook
How big is the screen on the loptop toshiba
The Toshiba Satellite A135S4527 has a 15.4" screen. (It is measured diagonally)
Mar 27, 2011 | Lifetime Toshiba Satellite A135S4527...
How to you troubleshoot my toshiba satellite M505?
Hello
OK, you will need o be more specific on the problem you want to troubleshoot. Please be more specific in order for us to give the most efficient help.
Kind regards
Andrea
Aug 31, 2010 | Toshiba Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Need take down instruction to fix a35 power addapter
Hello there:
if you do a google search
toshiba satelite a35 dissasembly instructions
there will be a big section on these laptops so make sure you get the right ones ok?
best regards mike
Aug 17, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
Power
Hi
download and install the toshiba controls program from ->HERE<-
Regards
Philip
Nov 03, 2008 | Computers & Internet
Toshiba Satellite P35-S605 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
